Old 11-17-2019, 01:28 PM   #1
Inverted flare
Looking for a 1/4" inverted male to 1/4" male npt or fpt
loyda is offline   Reply With Quote
Old 11-17-2019, 08:28 PM   #2
Head Rambler
Seems as if you're looking for a unicorn!
I can find male inverted flare fittings to hose barb, but male inverted flare to npt appears to be non-existent.
Do you mind telling me what you want it for?
Gotta go campin!
Old 11-18-2019, 07:30 AM   #3
Putting in a tee to add 100 lb tank. Trying to find a fitting to screw to one on automatic change over
Old 11-22-2019, 01:17 PM   #4
Made my own fitting .Click image for larger version
Old 11-22-2019, 02:34 PM   #5
yes, that would be a bastard fitting. the MIP is intended to seal at the tapered threads, the flare seals at the flare itself. Why not a sweat copper/MIP adapter?
You know they do make kits to connect a large tank to the existing regulator? It's called "Extend a stay"
nayther is offline   Reply With Quote
Old 11-22-2019, 09:24 PM   #6
It's a flare nut. Easy to screw to. only cost a couple dollars.
