Old 02-17-2018, 06:25 PM   #41
A couple of years ago when we had our Bullet trailer we had both propane tanks stolen.
I solve this problem by drilling a 1/2 inch hole in the big wing nut that holds them down and the same 1/2 inch hole in the cross bar that keeps them apart. Then drop a long shaft padlock thru these two holes and nothing is going anywhere.
Brandon2
brandon 2 is offline   Reply With Quote
Old 02-19-2018, 12:04 AM   #42
Tom48's Avatar
Brandon2
3/8s hole works for me. I can live with the questionable fire safety issue.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 02-19-2018, 05:29 AM   #43
There is no fire safety issue. They valves only need to be readily accessible
Old 02-19-2018, 12:34 PM   #44
Even if a Fire Department deemed it necessary to remove the tanks, they carry a "Universal Master Key" -------- Bolt cutters with long handles.
They use them to access anything with a padlock on it without bothering to wait for someone to find a key. They also carry a "Halligan Tool" which opens all kinds of doors, locked or not.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
batteries, lock, propane, tank
