I want to add a second low pressure propane quick disconnect at the rear on my RV for my Napoleon BBQ.
The front takeoff is an aluminum Tee which is bolted to the underside of the frame just like the tubular manifold which is fed with 3/8' rubber propane lines. The manifold has a spare port that I want to tie into and carry on to the rear of the trailer.
I cannot find a source of a 90 degree mountable bulkhead or single port manifold that I can bolt to the frame. I can buy the straight through bulkhead and would then need to build a bracket to mount it and add a 90 elbow to face outward. As for the 90 degree bulkhead where would I find that?
I cannot find manufactured mounting options to start with.
Any easy solutions
2017 Winnebago Micro Minnie 2106FBS, 2018 Toyota Tacoma Ltd 4 x 4
