Makes No Sense
2016 Sunseeker 3050S. Suburban furnace (have manual), Atwood water heater (have manual). Digital thermostat, set to Auto. NOT an electrician! At CG tow days ago, set up, full hookups. Ran city water throughout to finish flush sequence, HW heater full. Fired HW on gas, light right up. Fired stove, fired right up. Not cold enough to fire AC/heat pump or furnace..all is good. Yesterday, temps drop into 40's. Fire up heat pump, runs for a while, kits set point shuts down. Stares back up a while later, rig cooled down, unit starts cycling, fan off, compressor running, fan comes back on..just didn't seem right, shut it down, fire up furnace. Won't light. Fan starts runs 45/60 SEC, shuts down...3 try's, done. Will not run again until about 0230 when I tried to restart it, won't start past fan cycle. Tried heat pump, won't run. Heard HW heater cycle, faded out, then back full steam, faded, full blast, then shut down. Will not start.
Bled gas at stove, turned propane tank off, shut shore power off, disconnected house batteries. Let set. Opened propane valve as slow as I could, until full on, checked stove, lite right up. Reconnected batteries, switch ON, shore power On.
HW heater sparkler tries, shuts down after 2nd attempt. Furnace fan will not start. A/C Heat pump starts but will not cycle to fan start....
I know the propane & A/C are two different systems..would like ideas on HW heAter & furnace first...THANKs in advance!
2018 Georgetown 378 XL
Loved her, listed her, sold her
