Old 01-21-2021, 08:16 PM   #1
Male to Male quick connect hose
Hello,
I've been camping for a while but new to this forum...
Camper has an LP quick connect 'female' near the rear. I have a generator that can run on propane (also has a quick connect 'female') and would like to use that quick connect. However, I've been trying to piece together adapters and hoses for weeks with no luck! I'm guessing there's a reason they don't make/sell a hose with male to male quick connects on both ends.
I'm hoping someone here may be able to assist?
So far I've purchased a few LP hoses and adapters but the 3/8" NPT threads on the hose don't align properly with the threads on the adapters.
Any help will be much appreciated!
Thanks,
Chris
CWORL is offline   Reply With Quote
Old 01-21-2021, 08:39 PM   #2
take a trip to home depot and you should find everything you will need. you are probably going to need a quick connect fitting (comes with both the make and female end, you'll use only the male). you may need a npt bushing / adapter / fitting to adapt the fittings on the propane hose to the npt side of the female quick connect. take you hose with you and test fit the parts at the store. remember the yellow gas teflon tape and some soap solution to test for leaks.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-21-2021, 09:20 PM   #3
SailorSam20500's Avatar
I looked at Propanegear.com. What you want could be made by getting two Female POL x Male Quick-Connect Adapters and a 1/4" Propane Ball Valve that has male threads on both sides or a similar plain connector. Issue is, does the female quick connect on your trailer have a valve to prevent gas flow as soon as a male connector is attached?
You may be able to get the same parts at many big box stores.
Al
Save the Earth. It’s the only known planet with Beer.
When everything is coming your way, you're in the wrong lane.
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is online now   Reply With Quote
Old 01-21-2021, 09:31 PM   #4
"does the female quick connect on your trailer have a valve to prevent gas flow"
Yes, it does.
Old 01-21-2021, 09:32 PM   #5
Thank you. I'll try Home Depot again, maybe a different store in my area next time.
Will also check out propanegear.com!
Old 01-21-2021, 09:45 PM   #6
Maybe this:
https://propanegear.com/camp-chef-qd...-50-male-qc-8/
https://propanegear.com/3-8-x-1-4-brass-bushing/
https://propanegear.com/1-4-male-qui...e-pipe-thread/
? I'm going to give it a shot
Old 01-21-2021, 10:50 PM   #7
McRabbet's Avatar
The principal reason there is not a "stock" male-to-male hose is that it is a safety issue (think of an analogy with a male-to-male electrical cord -- if plugged in, the opposite male end would be hot and dangerous). If you plug one end in to a source of gas and the other end is loose, gas could flow freely. Our trailer outside gas outlets are female just downstream from a shutoff valve so gas won't flow. If you make up a hose, I would strongly recommend that you include a shutoff valve in the hose at the end where you intend to attach it to your generator. That way, that end would be less likely to be disconnected from the generator when the gas is free flowing because the valve at the trailer is still open; the hose valve should be closed before the generator connection is released.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
McRabbet is offline   Reply With Quote
Old 01-22-2021, 02:34 PM   #8
convert the generator fitting
If it were my generator I would change out the female fitting on the generator for a male quick connect, then I could use a standard M/F hose with the shut off on the female end. Solves the safety issue and follows standard installation practices.
HaulinMyHarley is offline   Reply With Quote
Old 01-22-2021, 03:37 PM   #9
Bob2019's Avatar
Any decent big box home store should be able to fix you up. I took off the regulator on my small Weber and had help finding the fittings to make the RV connection to the BBQ. While at it, also did a hose where I can hook up the removed regulator to a external propane tank with connectors if desired. You may need brass reducers, bushing, etc. but a knowledgeable person can help get you where you want to be. Personally, I love the convenience of not having to tote along a 5-20 lb tank. Hook up is so much nicer and quicker if you can tap the RV motorhome propane tank.
2019 Forester 2861DS
Bob2019 is offline   Reply With Quote
Old 01-22-2021, 09:28 PM   #10
X2
X2
Larry
Larry-NC is offline   Reply With Quote
Old 01-22-2021, 10:17 PM   #11
Usually Confused Member
emm-dee's Avatar
NAPA auto stores can usually custom make any kind of hose you need. Folks there are much more knowledgeable about that stuff than the big box stores.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 01-24-2021, 10:07 AM   #12
rollscanardly's Avatar
X3...I have done this to several propane items. This allows one to use a propane hose with a male/female end like an extension cord.
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 01-24-2021, 09:25 PM   #13
Two of these: https://smile.amazon.com/DOZYANT-Pro...1541117&sr=8-3
One of these: https://smile.amazon.com/Legines-Bra...1541210&sr=8-4
One of these: https://www.amazon.com/Harvey-017065.../dp/B000FKBXCE
Two of these: https://www.amazon.com/Crescent-AT21...54&s=hi&sr=1-6
That should do it.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
