Originally Posted by Plan Man
Mine has a regulator already connected that looks very difficult to remove so that hose wouldn’t work unless I remove the regulator.
You definitely will need to remove the regulator if you want to use low pressure LP from your RV
My Big Buddy has a separate port to attach the low pressure LP than where the bottles would connect.
Your other option would be to T off the high pressure line from your LP tank (before the regulator) and bring that to your Mr. Heater.
