No need to waste money on a new regulator if you don't have to. Simply get a replacement pigtail with a new one with 1/4" MPT, reassemble the check valve and install the new pigtail. To make it easy just remove the regulator and turn it sideways. If you're unsure of assembly order remove the other pigtail in vertical position and see how it is assembled. Another option is to get a CAMCO 59954 Adapter fitting (1/4" MPT to 1/4" Inverted Flare), with check valve already installed and get a new pigtail with an inverted flare end.
Or, you can go the route like NMWildcat suggested: Leave the check valve out and go with a straight through connection.
2016 Salem 27RKSS
