Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-05-2017, 08:18 PM   #1
No gas to stove or oven
Went camping this past weekend and everything worked Great except for the stove and oven. could not get stove or oven to light. Had propane and the gas water heater worked, could not get any gas to the stove or oven. I checked for any pinched lines, there were none. what could cause no gas to get to the stove or oven?
cyzenski is offline   Reply With Quote
Old 06-05-2017, 09:28 PM   #2
llr
Is this a new unit? There maybe a valve under the stovetop. If you hold a lighter near the burner when you turn it on is there any movement in the flam from air or LP coming out?
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 06-06-2017, 08:29 PM   #3
This is a year old unit. This is the first time stove or oven would not lite. there is no valve under the stove top that you can turn. there is a small square valve but no dials on it. there is no valve under the camper, just a gas line running to the stove, all copper. There is no flame movement when holding a lighter flame to stove burner. just do not understand.
Old 06-06-2017, 08:49 PM   #4
llr
I was thinking I saw a valve on mine, it is a pressure regulator under the stovetop where the copper gas line attaches.
All​ I can think of is the regulator is bad since you said other devices are working on propane
Old 06-10-2017, 06:34 AM   #5
I had the same problem on my TT. If your stove is on a slide-out, I'd bet that you either find a pinched line or maybe something blocking the line.
kluza2786 is offline   Reply With Quote
Old 07-01-2017, 09:27 PM   #6
Found a toggle that controls stove & Combi
We have spent a year with the hot water bearly working, we finally found the propane valve is controlled by a toggle on the propane fill panel. It seems our dealer forgot to turn it on after filling the tank.
Mikecam is offline   Reply With Quote
gas
