On my trailer...
On my trailer, every gas appliance is fed by a separate home. Under the belly of my trailer is a section of T connectors and a hose going to one appliance so it would not be likely that two appliances would die because of one plug.
The water heater not lighting could be a bad controller - lots of advice here on controllers. The BBQ likely is caused by the gas hose not being inserted far enough into the connector. The outside shell of the trailer side needs to fully close on the nipple. Pull on the hose and see if it comes out - if wo, it needs to be inserted farther, let the connector snap AND turn on the gas on the trailer side by rotating the handle in line with the hose.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
