Old 04-22-2021, 08:07 PM   #1
No heat
So i went to turn on my Suburban furnace NT30SP for the first time this year and no heat i can hear clicking and smell gas but it wont light any help would be greatly appreciated this camper is new to me it is a Rockwood
robertbm is offline   Reply With Quote
Old 04-23-2021, 07:50 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. Use the internet and pull down the troubleshooting guide for your furnace. It could be a problem caused by spider webs or the sail switch . I use air to blow out my combustion air and exhaust before each season to eliminate webs and such
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-23-2021, 08:40 AM   #3
thank you i will give that a try
Old 04-23-2021, 11:43 AM   #4
i took the furnace out and checked the sail switch and all was good cleaned everything
still no a no go on it lighting my stove also has low flame
Old 04-23-2021, 11:48 AM   #5
Fully COVID-19 vaccinated
Did you purge the air out of the propane lines? I typically turn on a stove burner and hold a lighter next to it until it lights.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-23-2021, 11:59 AM   #6
You need to keep that stove lit until all the air is purged from the system and you get a good flame. If the stove doesn't get a good flame, then you've got a propane supply problem.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 04-23-2021, 12:01 PM   #7
Big LP use items like the furnace and the water heater require that you be able to light all the burners on the stove on high and have a good flame before considering the possibility there is something wrong with them.
If you don't have good flame at the stove you should start by investigating whether you have a LP supply issue.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=90
Old 04-23-2021, 12:03 PM   #8
Kanadian Kamper
kenandterry's Avatar
So.....we’re assuming you have lots of propane right?
Turn the valve closed. Wait a minute. Then open it slowly to full open.
Make sure all stove burners work properly for at least 1 minute.
Assuming battery is good....try furnace again.
If you have water in your system, try your propane water heater, and test for hot water.
Ken and Terry
2018 Sunseeker 2430S-CD carried by a 2017 Ford E450
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 04-23-2021, 02:35 PM   #9
Tombsy's Avatar
When my built in regulator (motorhome) got stuck in low flow mode the furnace wouldn’t light but I had one burner that would light and a second burner that had a low flame.
The first time it happened I replaced the regulator but the second time hot water got it to reset.
I believe the low flow is built into your tank valves and Kenandterry gave you the procedure to reset them.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 04-24-2021, 09:44 PM   #10
I would like to thank you all for your input . I got it all fixed all is good now camping hear we come .
Old 04-24-2021, 11:11 PM   #11
bikendan's Avatar
It would help others if you posted what the fix/solution was.
Old 04-25-2021, 07:34 AM   #12
Glad everything is in order and thanks for letting us know.
Could you possibly share what fixed it so if others have a similar issue, maybe your fix will help them?
