Old 10-10-2021, 08:00 AM   #1
No Propane at Stove
I was not getting any propane at any of the gas appliances and discovered it was a problem with the Cavagna regulator on my camper.
We disconnected the main line coming out of the regulator and got nothing to come out after opening the tanks. Just below the gauge, there is a small, gray, plastic hex nut. It covers the regulator's output pressure adjustment screw. I gave that a 1/4 turn and gas starting coming out!
Put it all back together and now it's working the way it's supposed to. Quick fix 😀
skottmorris is offline   Reply With Quote
Old 10-10-2021, 09:21 AM   #2
SeaDog's Avatar
before you start using things you need to put a manometer on the output and adjust the water column to the correct gas pressure. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-10-2021, 09:57 AM   #3
NMWildcat's Avatar
Agreed. Personally I would just replace the regulator. There is a reason it stopped working initially.
Scott and Liz - Southern NM
propane
