Old 10-30-2018, 10:36 PM   #1
Nothing is getting propane! Help!
So nothing is getting propane. Not my stove, not the fridge, not the heater, not the water heater. NOTHING! I bought a new regulator with new tubes included, have a working propane tank and nothing is working still. Is there a chance that the tube running from the regulator to the piping that runs throughout the trailer is bad? Is there a safety valve I’m not seeing? I’m so stumped.
Rhenneman12 is offline   Reply With Quote
Old 10-30-2018, 11:00 PM   #2
B and B's Avatar
Hello,
Propane cylinders and hoses have a failsafe valve inside. If opened too quickly they well **** off right at the tank,
Make sure all appliances are shut off first.
Then open the propane cylinder valve very slowly.
There are two stages to each regulator assembly. Do you have any pictures. trailer model, fifth wheel or Travel Trailer. All have different components.
BC
Old 10-31-2018, 06:19 AM   #3
I had same problem this past Summer. I bought a new regulator (Mr. Heater brand) but it didnt help. Bought a new Marshall 2 stage and new pigtails. One side worked but the other didnt and I smelled propane. Checked all connections and found another small regulator on other side so replaced it. I also found that the 11 foot propane line that went from the main regulator to small one was bad as it leakes and fitting was real loose in the line. I had a new one made by propanegear.com. Now all is good. System works great
OKI Marine is offline   Reply With Quote
Old 10-31-2018, 09:47 AM   #4
Originally Posted by B and B View Post
Hello,
BC
This is the first thing to try.
jeffnick is offline   Reply With Quote
Old 10-31-2018, 10:01 AM   #5
Rhenneman12 welcome to the forum. I see this is your first post and I'm sorry you are having issues.
It is ALWAYS helpful to post the make and model of your rig so everyone can give better answers. Also you might want to set up a signature line so that information is in every post you make.
Couple quick questions...
Did the propane system ever work?
If this is a new unit, did the stove, oven, refrigerator, water heater and furnace operate correctly during your PDI/Customer Orientation?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=90
Old 10-31-2018, 11:13 AM   #6
Hi there! It’s a forest River Evo Travel Trailer. I tried turning on the propane tank slowly this morning but it still didn’t work. Looks like someone below suggested it might be the propane lines?
Old 10-31-2018, 11:24 AM   #7
If it's never worked then I suspect the main line or hose is kinked or plugged before the first appliance. You can take the hose loose at the main line and blow through it to see if it's plugged.
Gotta go campin!
Old 10-31-2018, 11:33 AM   #8
Is there just 1 tank? I know on our camper there is 2 tanks with a switcher between the 2. Is the switch, by chance "in between" if there are 2 tanks.
KKonyha is offline   Reply With Quote
Old 10-31-2018, 11:37 AM   #9
Is it brand new?
You shouldn't have to be chasing down this issue.
Your dealer should be taking care of this!
Old 10-31-2018, 02:08 PM   #10
Have you check your battery? The gas valve will not work if the RV battery is not charged.
tomrob1161 is offline   Reply With Quote
Old 10-31-2018, 02:13 PM   #11
Depends on the year of the Trailer. My 02 has no battery control. There is no electric shut off valve.
Old 10-31-2018, 02:19 PM   #12
I had a similar problem but not the total system, just the BBQ outlet.
For some reason they used hose all the way from my regulator to every single appliance. Found a kink that shut the BBQ line totally off.
Since you have NO propane, I'd first check to see if you have any in the tanks. Assuming you've done that already, check the hose from the regulator back to it's first junction. Make sure it's not pinched off.
Lastly, is the changeover knob/lever all the way to one side or the other?
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-31-2018, 02:21 PM   #13
Power to operate propane?
I have owned two popup trailers and three hard side trailers and a camper and there was never any connection between the battery and the propane system.
Here is what I would do - in this order:
1 Is the changeover valve half way between the two positions?
2 Is the tank heavy and sloshes when you rock it?
3 Will the tank work on a BBQ or a space heater?
4 Can you trade another tank for the one you have that isn't working?
5. Can you disconnect the hose from the bottom of the regulator? If so, turn the tank valve on and listen for gas flow at the regulator. If nothing, the problem is in the regulator. As mentioned there is a valve that shuts off the flow if there is a big leak. To reset this valve, turn off the gas valve at the tank, loosen the regulator to tank fitting, tighten it up and turn it slowly on. Check again.
6. Stoves do not require any DC voltage so a burner should light if there is flow. Still not working? Start looking for a kinked hose under the trailer that comes from the tank. Water heaters and furnaces require battery power to open the propane valve to the appliance.
Good luck...…..
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is online now   Reply With Quote
Old 10-31-2018, 02:56 PM   #14
Kanadian Kamper
kenandterry's Avatar
Tons of help trying here.......
Rhenneman12......
We’re trying to help here, but let’s get back to basics.
You’ve just joined the forum as of October 2018 in your signature.
1. Is this a brand new rig, or just new to you.
2. Have any of your gas appliances ever worked.
Sorry 5picker you already asked, but there was no answer.
Ken and Terry
2018 Sunseeker 2430S-CD carried by a 2017 Ford E450
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 10-31-2018, 03:05 PM   #15
Vince and Charlette's Avatar
I'm surprised no one has asked if there is an odor anywhere. Most two-stage regulators have a small port about 1/8" (that is supposed to be pointing down). See if you can smell propane a that port...use the saliva test to see for sure. If so, then you likely have a failed regulator. Regardless, some of the instructions above are good. Always open the supply valve very slowly; and always watch the person filling your tank to make sure the supply valve is closed before filling. An overpressure can easily damage the internal regulator valves. And, carry an extra regulator. Surprisingly, Lowes carries some universal models.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 10-31-2018, 04:32 PM   #16
amblt's Avatar
I had an interesting event a few weeks ago, related to the question of safety devices.
I had a 20 lb tank empty, so I replaced it with a tank recently filled. After hooking up to the RV, I couldn't open the tank valve - my strength is not what it used to be due to age and a broken wrist 3 years ago, but it was strange. After I used the most force I considered safe using the slipjoint pliers, I turned the valve (by hand) clockwise and it closed. Obviously the chap who filled it left the valve open-and the safety device worked ok. All seems good, we had propane 'till we closed the RV.
Cheers
amblt is offline   Reply With Quote
Old 10-31-2018, 04:48 PM   #17
no propane.
Does it have a propane leak detector? If so is it turned on. Check for a valve with 2 wires to just after the regulator and the main hose exiting it. I have this on my George Town and it must be turned on.
Daddystribe is offline   Reply With Quote
Old 10-31-2018, 04:50 PM   #18
I'm Lost
wabakami's Avatar
Welcome to the forum.
As others have said, we still need more info to be able to help you.
Did you try running a stove burner, put your ear to it and listen, if there is a hissing sound then it may be as simple as unpurged lines. My TT (35' rear kitchen) can take upwards to 2 minutes to get the stove to light after an extended shutdown, I always light the stove to get the propane flowing first then turn on the fridge, etc as most of the automatic appliances will go into safe mode if no ignition and shut themselves off.
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2013 F150 Screw, 6.2L gasser, HDPP, LT tyres, Firestone Air Bags, 250L aux tank.
2013 Rockwood Signature 8310SS
wabakami is offline   Reply With Quote
Old 10-31-2018, 05:03 PM   #19
Until the OP comes back and answers some questions, we are all just spitin' in the wind.
Old 10-31-2018, 05:21 PM   #20
Mr. Dan's Avatar
Yes... this ^^^^^
If the OP returns and gives some answers to use as clues, we're kinda wasting time. Answers to a couple of these questions should hash this down fairly quickly.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
propane
