Originally Posted by Wildman13
Hello all,
We have a 6 gallon gas / electric.
When there is a gentle breeze blowing it has problems lighting. You can hear the gas catch like a small explosion as it blows itself out as it catches all at once.
If the wind is stronger it catches and stays lit just fine.
If I hold up something to block the wind it catches then stays lit.
Is there something that needs to be adjusted?
TIA
Is this on a new or older RV as you don't have your RV make/model listed?
You may possibly need to "clean" the burner flue instead of "adjust"anything. Bugs/spiders are known to get inside the burner flue and clog it up that can help cause hard to light problems which could be compounded by the wind.
You could also have a misaligned/misgapped electrode that makes the sparks for the gas to ignite.
Some members have made an air diverter that can be placed on the water heaters outside cover to keep wind from directly blowing.
