Old 12-31-2018, 12:50 PM   #1
srea1957's Avatar
Location: Next to tree-covered and peaceful Boyle Park :-)
Off-The-Grid Propane Washer/Dryer Combo?
Is there a washer/dryer combo that works with propane for off-the-grid camping? Or, should I stick with a unit like this LG using a generator? (I'm thinking generator.)
Stephen Rea
S.W.A.R.M. Search and Rescue
Interim Arkansas area director
(SAR using thermal camera equipped drones)
Flagstaff 25D YouTube video: https://www.youtube.com/watch?v=0k-HZNu0Zlo
srea1957 is offline   Reply With Quote
Old 12-31-2018, 01:18 PM   #2
I have seen some 24v DC washers, some solar powered washers and those washers spun by hand but I have not seen a LP powered dryer for R/V use without electricity.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 12-31-2018, 02:00 PM   #3
bikendan's Avatar
Probably the only way is to use a propane powered generator, to provide electricity for the washer/dryer.
Equalizer WDH
Old 12-31-2018, 02:10 PM   #4
rsdata's Avatar
I would hate to use a washboard in the river in place of the washer, but a good old fashioned clothesline rack (Maybe one of those compact ones) might be better and certainly cheaper. than any dryer. Sheets dried in the sun and wind feel so nice...
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 01-01-2019, 03:06 PM   #5
D W
D W's Avatar
Absent a propane powered generator, I don't see any possible way propane alone could power a washer or dryer.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 01-01-2019, 04:12 PM   #6
Don't any of you folks remember the gasoline engine powered washers that used to be common in the country? Simple to convert a gasoline engine to run on propane.
The solar powered dryers work best when boon docking. You can pick up a hank of clothesline and pins for likely less than a fiver at the big box stores.
Jerry & Sally Martire
Culpeper, VA
2008 FR Flagtstaff 831RLSS
2004 Silverado 2500HD diesel
transmission_doctor is offline   Reply With Quote
Old 01-01-2019, 04:45 PM   #7
A washer uses too much water for off the grid camping. You would rapidly use up your fresh water and I don't advise dumping the soapy water out on the ground. Unless you have a water source and a septic system to accommodate the soapy water I would suggest hand washing and use a clothes line.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 01-01-2019, 09:58 PM   #8
srea1957's Avatar
Good points, Wilco.
Good points, Wilco.
Stephen Rea
Old 01-01-2019, 11:35 PM   #10
Camp Maytag
This is what we did/used in scouts.
Camp Maytag
Kf4mnc is offline   Reply With Quote
Old 01-02-2019, 07:03 PM   #11
Clothes washer,dryer
Try Lehman's. They are based out of Ohio, & have a website & catalog. Many options. I use a plunge washer camping. Works great & less than $20.
Skip3762 is offline   Reply With Quote
