Old 09-11-2020, 09:23 AM   #1
Propane
Are there do's and don'ts for having your propane on while towing your RV down the road? Is it legal?
Stewart W is offline   Reply With Quote
Old 09-11-2020, 09:36 AM   #2
I do it to keep frig going. Tunnels may require you to turn it off before going thru.
TheWolfPaq82 is offline   Reply With Quote
Old 09-11-2020, 09:38 AM   #3
007matman's Avatar
I've done it for years. No issues at all.
There are a few tunnels where they will tell you to turn it off. However, I'm gonna bet that most of the time RV owners don't. I've gone through those tunnels before but never with a camper hooked up.
If you have a 2-way or 3-way fridge it'll keep the coldest off of propane. That's how we use it all the time. I only flip to using electricity when I run out of gas.
Some complain that their flame goes out.. I've never had that problem.
007matman is offline   Reply With Quote
Old 09-11-2020, 09:45 AM   #4
Turn the LP tanks off before you pull up to gas pumps.
2020 Flagstaff Micro Lite 22FBS
Old 09-11-2020, 10:04 AM   #5
007matman's Avatar
Why? Do they normally have open flame by the gas pump at your local gas station?
Old 09-11-2020, 10:37 AM   #6
BriaBeck's Avatar
If I'm understanding your question, You have a flame in your refrigerator, if it is turned on.
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
Old 09-11-2020, 11:13 AM   #7
007matman's Avatar
Under metal shielding and vented properly, but yes. I wouldn't call it an open flame as it's burnt and exhausted immediately through approved ducting.
Old 09-11-2020, 11:28 AM   #8
BriaBeck's Avatar
I'm not disagreeing with you.
But, the risk is present that under the right conditions, that little flame could ignite gasoline vapors present at a gas station.
Unlikely, but still possible. Or, stated another way, not impossible.
Brian & Becky
Champion 3500
Old 09-11-2020, 11:53 AM   #9
NMWildcat's Avatar
That reminds me, I need to upgrade my anti meteorite helmet to include foil to prevent alien mind intrusion.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-11-2020, 11:54 AM   #10
If you just turn off the tanks, it takes awhile for the flame to go out at the fridge. Just turn the fridge off.
I never bother. My fridge is 30 feet away from my truck fuel tank.
babock is offline   Reply With Quote
Old 09-11-2020, 11:57 AM   #11
007matman's Avatar
I totally forgot about that too!!
Old 09-11-2020, 12:00 PM   #12
SlowrideHD's Avatar
I have never turned mine off in over 40 years of rv's with propane/electric refrigerators. Have never had a problem.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 09-11-2020, 01:02 PM   #13
BriaBeck's Avatar
I don't bother either.
Brian & Becky
Champion 3500
Old 09-19-2020, 11:09 PM   #14
If you are going to shut off the fridge while fueling, it is far better to turn it off electrically with the switch rather than just shutting off the propane tank valves.
NavyLCDR is offline   Reply With Quote
Old 09-20-2020, 06:35 AM   #15
TowPro's Avatar
Any tunnel I have gone through that requires propane be shut off also includes a required stop where they ask you if it's off. And the 2 tunnels in Baltimore don't allow propane containers over 10 lbs at all (rt 95)
No RV currently
TowPro is offline   Reply With Quote
Old 09-20-2020, 06:57 AM   #16
Oaklevel's Avatar
You will get opinions both ways.
There have been a few fires while refueling but it is rare. About 10 years ago a motor home was going through a tunnel here in Virginia and had a propane fire and closed the tunnel for several months........ bet their insurance company loved it.
But as I said its rare........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-20-2020, 07:16 AM   #17
PhD, Common Sense
Fires caused by smoking while refueling are also rare.
I still asked the last guy I saw smoking at the pump to please put it out. He didn’t. He made some kind of comment about not smoking at the pump being BS. He probably thought I was some kind of rules/smoking/fueling/propane/weight/axle/tire Nazi.
I wasn’t going to start a fight. The gas station did not catch fire. This time.
But, hey folks, while you are doing you, remember that, even if you don’t survive a disaster that kills others, much of your family will have to live with the aftermath.
eye95 is offline   Reply With Quote
propane
