Old 11-28-2022, 03:40 PM   #1
Propane cutoff on swing-away galley
I just acquired a 2022 Flagstaff 228BHSE popup camper from the original owner, so no warranty coverage. I cannot get the cooktop burners to light. (It appears they've never been lit.) All other gas appliances work just fine. I suspect it may be the 'button' under the swing-away galley. Propane cutoff? Any suggestions?
cairnwalker is offline   Reply With Quote
Old 11-28-2022, 04:22 PM   #2
bikendan's Avatar
Moved thread to the Tent Camper and Popup section since popups differ many ways, from other types of RVs.
Old 11-28-2022, 06:29 PM   #3
Maybe...
After you've checked all of the other stuff, remember that RV ranges have a secondary propane regulator, right under the cooktop. Never heard of one failing, but it's a (remote) possibility.
Larry
Larry-NC is offline   Reply With Quote
Old 12-07-2022, 06:46 PM   #4
The "button" under the swing up galley is for cutting off 12V electricity power to the RV. Its there so you don't run down the battery because you forgot to turn off a switch and can't when its closed.
Outside of obstructions in the line or regulator failure on the stove I have no idea assuming is plumbed correctly.
flyerdp is offline   Reply With Quote
propane
