Old 08-05-2022, 05:51 PM   #1
AT-82Collectors's Avatar
Propane hose failed
I normally keep both propane tanks shut off while my camper is in storge. I turned one tank on to insure my fridge would work on propane before we left on a trip. I came back after a couple of days to find this and a empty tank. Glad it happened in storage and not on the road or while camping.
2017 Cherokee Limited 304
2013 F250 Platinum Super Duty 6.7
Blue, Sam and Spike copilots
AT-82Collectors is offline   Reply With Quote
Old 08-05-2022, 06:13 PM   #2
NMWildcat's Avatar
Don't replace it with those premade pigtails you find everywhere. Go to your local propane distributor and get them to make you one. It will be better quality and probably cheaper
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-05-2022, 07:25 PM   #3
You're going to replace both of them, right? That would have been scary if it happened on your trip.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-05-2022, 07:36 PM   #4
Good advice NMWildcat. I will have them made local. I did purchase two replacements but they just don't feel right, too much teflon tape to get them to seal.
Old 08-05-2022, 07:44 PM   #5
Propane Hose
I replaced both of ours from the tank to the regulator with the braided SS types found in the Lawn & Garden department at LOWE'S. They seem to seal without using any Teflon tape going into the regulator. In fact, by design, they shouldn't need any.
Bob
Bob K4TAX is offline   Reply With Quote
Old 08-07-2022, 11:29 AM   #6
Bob
If the pigtail ends in NPT fitting it certainly does require teflon tape or pipe sealant.
https://www.amazon.com/Stainless-Con...dp/B07ZCRFLHD/
Inverted flare fittings are metal to metal sealing and neither teflon tape nor pipe sealant should be used on them.
NavyLCDR is offline   Reply With Quote
Old 08-07-2022, 11:40 AM   #7
LP Hose
The correct fitting is a reverse or inverted flair fitting. No tape or sealant is required.
Bob
Old 08-07-2022, 11:52 AM   #8
NMWildcat's Avatar
Bob
Correct for what? Most RV propane regulators I have worked on have 1/4" and 3/8" inlet/outlet with NPT threads. Some regulators come with adapter or check valve fitting that has NPT on regulator side and flare on the other (pigtail side).
Old 08-07-2022, 12:06 PM   #9
And the regulators that come with the adapters installed from the factory usually have red pipe sealant on the regulator side of the adapter.
Old 08-07-2022, 12:07 PM   #10
NMWildcat's Avatar
Exactly
led, propane
