Old 08-09-2020, 12:53 PM   #1
Propane Leak
In our 2014 Forest River Georgetown 360XL we got home from a trip and heard a hissing and smelled propane - strongly - outside. I opened the propane basement door and the hissing was coming from under a plastic protector that is over the regulator valve. When I turned the valve off, the hissing stopped. I moved the plastic dust-shield out of the way and it appears that a screw or something fell out of the bottom of the regulator. In the photo, I've pointed at where there is an empty spot that the hissing is coming from.
/Users/stephenwolfer/Desktop/IMG_2119.jpg
swolfer is offline   Reply With Quote
Old 08-09-2020, 02:12 PM   #2
Picture is fuzzy when enlarged but is that opening labeled "Vent"?
If so nothing fell out, the regulator has failed. Internal diaphragm most likely has a hole in it and the regulator needs to be replaced.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 08-09-2020, 02:21 PM   #3
Thanks! That is indeed labeled "vent" - it is a 524AS regulator and it puts my mind at ease knowing this isn't one of those repairs that will cost an arm and a leg.
leak, propane
