Old 04-21-2021, 05:17 PM   #1
Chet C
Propane noise
When my propane is being used, ie.. furnace running, water heater running, I have a whistling or squealing noise from around where my tanks are on the tongue. I don't smell any gas. I was just wondering if this a normal event. I don't happen every time...but most.
Any ideas??
ChetC is offline   Reply With Quote
Old 04-21-2021, 05:21 PM   #2
Flybob's Avatar
You are hearing the regulator regulating the propane flow. Normal under high load.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-21-2021, 05:23 PM   #3
Originally Posted by ChetC View Post
When my propane is being used, ie.. furnace running, water heater running, I have a whistling or squealing noise from around where my tanks are on the tongue. I don't smell any gas. I was just wondering if this a normal event. It doesn't happen every time...but most.
Any ideas??
It's not uncommon to hear the regulator squealing when using a high flow device. It's most the diaphragm vibrating on the seat. I'd start looking around for a new regulator. it probably won't be long before you need one.
Gotta go campin!
