Propane pressure question
I've not tried this yet, so before I really screw up, I thought to ask for advice.
I want to connect my RV LP tanks via the quick connect to my Coleman 1lb camp stove and a small propane 1lb grill by way of a splitter. My concern is that the RV tanks are already equipped with a pressure regulator and the Coleman stove and grill also have a pressure regulator each. Will this idea work or will the gas pressure be so reduced that a proper flame is not possible in either the grill or the stove? And if that is the case, is there a way to make this work with some modification of equipment? The RV is a 2021 Rockwood 2608BS with 30 lb tanks. Thanks in advance for your help. SteveG
