Originally Posted by discjocks
Photo is upside down, I’m wondering if I can use the quick disconnect to plug in a outside grill. How do you tell if the gas pressure is regulated ?
Steve
It depends on the grill, on which you can use the quick connect.
You will need a low pressure grill to use it as is (like a sidekick or RVQ). These type grills do not have a built in regulator.
https://ouioutdoors.com/product/sidekick-grill/
Now if you use a grill with a pressure regulator on it, then you are regulating it twice (and will have low fplame/pressure) and these types usually do not work with the quick connect. You have to modify the grill to take out it's built in regulator. We have many threads on such.
https://propanegear.com/coleman-road...it-gen-2-8-ft/
