Old 10-13-2012, 05:40 PM   #1
RalphieAdie's Avatar
Propane quick connect & grill
We just took possession of our new RV, which included a National Supply Model # YH1801RV Portable LP Gas Grill. The RV has a propane quick connect also. Unfortunately, the quick connect propane line won't connect to the grill. The two just don't appear to click together as they should. Has anyone else had a problem like this?
Thanks.
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 10-13-2012, 05:47 PM   #2
MtnGuy's Avatar
Pull the collar back as you try to insert the coupling. You might need a a little WD-40 to make the fitting work better.
Old 10-13-2012, 06:55 PM   #3
Did that, still doesn't snap in place.
Thanks.
Ralph & Adrienne
Old 10-14-2012, 02:49 PM   #4
bikendan's Avatar
never heard of this grill. most FR products get the SideKick Grill.
so, no idea what kind of grill you got.
does the grill's paperwork list a website?
Old 11-20-2012, 09:21 PM   #5
Sounds like a mis-matched coupling on the grill. Take a close look at the p/n on the coupler; the 5LP series are for high pressure while the 250 series fittings are for the low pressure system used on campers and generally found only in RV supply centers. Even though you can insert one into the other, they won't click to seal.
Sirsea is offline   Reply With Quote
Old 11-20-2012, 09:31 PM   #6
The grille brand and model # doesn't show up on Google. Perhaps the grille is some offshore substandard thing??
As stated, with the right connector, it will click in place, but you should pull back the outer ring (if that's what it's called) to allow the connector to go in. Just like fittings on an air compressor.
You may need to buy a complete hose and replace the one on the grille. But then, shouldn't the dealer be responsible for making this work right?
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 11-20-2012, 09:41 PM   #7
We disconnected the connector from the grill and sent it back to our RV dealer. Yes, it was the wrong size connector. They just sent us a new part and now it works great. Thanks for all your help.
Ralph & Adrienne
Old 10-31-2015, 07:17 AM   #8
OswegoLion's Avatar
I have the same grill. Where is the hose for it? It wasn't in the bag.
OswegoLion is offline   Reply With Quote
Old 10-31-2015, 10:47 AM   #9
It's in the side of your rig. Thanks for replying.
Ralph & Adrienne
Old 10-31-2015, 11:09 AM   #10
OswegoLion's Avatar
Underneath??
Old 10-31-2015, 12:53 PM   #11
Ours comes out of the side of the rig, near the door. What model do you have?
Ralph & Adrienne
Old 10-31-2015, 12:54 PM   #12
OswegoLion's Avatar
2016 Flagstaff 8528 IKWS.
Old 10-31-2015, 01:14 PM   #13
We recently upgraded our rig to a Flagstaff 8527CKWSA. Here is where the propane connection is located on our rig.
ID:	93378   Click image for larger version
Ralph & Adrienne
Old 11-30-2015, 02:46 PM   #14
gdl
gdl
where can I find this yh1801rv-1 grill? national supply only at $209.00? my2011 flagstaff 26rls did not come with it
gdl is offline   Reply With Quote
