Old 10-27-2011, 11:51 AM   #1
Propane Tanks
This will be my first question to ask you all about winterizing your TT.
I blew out my water lines after draining all water, added Camco antifreeze to p traps and I'm hoping I did everything right since it is our first TT.
Now I need to know if I should fill both propane tanks before I cover it for winter?
Thank you all!!!
elroseo is offline   Reply With Quote
Old 10-27-2011, 11:54 AM   #2
MtnGuy's Avatar
The propane tanks can be stored full, empty, or anywhere in between.
I only fill mine when 1 goes empty.
Old 10-27-2011, 03:39 PM   #3
BigDTx's Avatar
X2
BigDTx is offline   Reply With Quote
Old 10-27-2011, 05:47 PM   #4
3 Happy Campers's Avatar
The rule of thumb I was told when we first started RVing 20 yrs ago was to fill the tanks before winter storage. This would prevent condensation & corrosion from developing on the inside.
With the newer tanks that can only be filled to 80% the rule does not completely apply.
I guess you are still protecting 80% of the tank.
I for one fill my tanks for storage just because thatís $$$ I donít have to fork out in the spring when Iím getting everything ready for the season.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 10-27-2011, 08:17 PM   #5
Lottery Non-Winner
Ovair's Avatar
Conventional fuel tanks are vented and therefore are breathable. LP tanks are not only sealed but are pressurized. Moist air cannot migrate in and out. Any moisture that might be inside is all it will see. But there shouldn't be any if it was purged right. It matters not how full or empty LP tanks might be. This is not true for gasoline tanks, diesel tanks, kerosene tanks, etc...
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 11-18-2011, 05:12 PM   #6
Brigitte
boubou's Avatar
Should the propane tanks be removed for the winter? they have a plastic cover on them now
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 11-18-2011, 05:21 PM   #7
daydreaming about camping
jeeplj8's Avatar
They do not have to be.
Generally is is discouraged to store propane tanks inside.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 11-18-2011, 05:51 PM   #8
dretired's Avatar
Thank you all!!!
Did you drain the hot water tank ??
dretired is offline   Reply With Quote
