Old 02-21-2024, 03:04 PM   #1
Rv carbon monoxide/propane alarm replacement
Our 2019 Rockwood MiniLite 25BDS needs a co2 detector replaced. The model that came installed is a SAF-T-ALERT model 25-742. Can I replace it with a 25-741 model? Whatís the difference other than $75 vs $130? Are other manufactured brands acceptable to use?
MOcamper52 is offline   Reply With Quote
Old 02-21-2024, 04:49 PM   #2
RedLdr1's Avatar
Welcome to the forum. A look on line shows the 25-741 is RV approved. I suggest contacting MTI, the manufacturer SEE HERE, at 800-383-0269 and they should be able to answer any questions and warn you about any "gotcha" issues.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
RedLdr1 is offline   Reply With Quote
Old 02-21-2024, 05:25 PM   #3
Kcoulter's Avatar
Looks like the difference is surface mount vs flush mount
25-741 (Surface) https://www.mtiindustries.com/produc...ce-mount-mini/
25-742 (Flush) https://www.mtiindustries.com/produc...sh-mount-mini/
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
Kcoulter is offline   Reply With Quote
Old 02-21-2024, 06:06 PM   #4
Chuck_S's Avatar
"RV Approved?"
But don't worry. CO2 is harmless (but I bet you meant CO).
Lowes, Home Depot, and Amazon will have enough different models to make your head spin. Just find one that uses batteries you like.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 02-21-2024, 07:17 PM   #5
REL
I just replaced my surface mount with this one
https://www.amazon.com/gp/aw/d/B0C4L...b_b_asin_title
REL is offline   Reply With Quote
Old 02-21-2024, 07:17 PM   #6
RedLdr1's Avatar
Originally Posted by Chuck_S View Post
"RV Approved?" -- Chuck
Their marketing claim, on both units, not mine.
Wayne
Old 02-21-2024, 07:54 PM   #7
That's because they come with a roll of toilet paper that's approved!
Rick & Akela(GSD)
GoingNoWhereFast
2017 4runner SR5 with mods
2008 Aliner Classic with Many Mods (in Rehab)
2020 FR Wolf Pup - 660watts Solar, 300AH LiFePO4, Inverter, WFCO-LIS converter, And many mods
GoingNoWhereFast is offline   Reply With Quote
Old 02-21-2024, 08:04 PM   #8
You all have been very helpful. Thank you so much.
Old 02-21-2024, 08:55 PM   #9
Chuck_S's Avatar
"RV" detector runs on 12vDC. Works on your boat too. "Marine" detectors cost more.
-- Chuck
Old 02-21-2024, 09:02 PM   #10
Some detectors have a third wire feeding a solenoid which shuts of propane when in alarm. Check yours first for two wire verses three wire.
Cross-threading works better than blue loctite.
Capacitor is offline   Reply With Quote
Old 02-22-2024, 12:56 AM   #11
Amazon has a direct replacement model. That's the easiest to install.
SAF-T-ALERT model 25-742 https://www.amazon.com/Safe-T-Alert-...s%2C167&sr=8-1
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 02-22-2024, 02:11 PM   #12
Nope
First of all, the 2-wire vs 3-wire thing is for propane detectors, not CO2 detectors.
Second, the 3-wire units are mostly used on motorhomes, not trailers.
Larry-NC is offline   Reply With Quote
Old 02-22-2024, 02:36 PM   #13
Very generalized response.
Amazon has a great selection of RV supplies. Other retailers do, too. Amazon is a great place to start your hunt, find the item you want, and then do a general search by brand/model.
eTrailer is another great source, but their site isn't as slick as Amazon. That's why I suggest you start there.
CLICK: RV propane CO detectors They even sell your brand with prime shipping for $68.
Obviously, the abundance of choices requires that you pay attention to things like dimensions, etc. if you plan to find an exact fit.
I mostly posted this to point you to Amazon for almost anything for an RV, from electric tongue jacks to potable water hoses, to, in some cases, replacement taillight fixtures. Often times you can save a LOT by not buying manufacturer replacement parts...which, by and large, are off the shelf stuff they simply buy in bulk. And if they resell to you, the markup can be nuts.
My RV microwave bit the dust, and I bought a perfect fit replacement of another brand through Amazon for far less than I would have paid a dealer.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
jimmoore13 is offline   Reply With Quote
Old 02-22-2024, 04:59 PM   #14
First of all, the 25-742 is a dual alarm for both propane and CO.
Second, the 3-wire thing can also be used in trailers.
Old 02-22-2024, 05:49 PM   #15
Why not say so?
Umm, all the posts prior to mine referred to a "CO detector." There was no reason for me to look it up. Eleven (!) posters ahead of me could have made that observation.
Yes, of course. But only on propane or combination detectors. Not on a CO detector.
Larry
Old 02-27-2024, 12:10 AM   #16
"RV Approved?"
-- Chuck
CO2 is not harmless, otherwise it would not be effective in fire extinguishers. CO2 displaces oxygen.
NavyLCDR is offline   Reply With Quote
Old 02-27-2024, 06:41 AM   #17
Oaklevel's Avatar
"RV Approved?"
-- Chuck
CO2 Harmless ???
Symptoms of mild CO2 exposure may include headache and drowsiness. At higher levels,rapid breathing, confusion, increased cardiac output, elevated blood pressure and increased arrhythmias may occur. Breathing oxygen depleted air caused by extreme CO2 concentrations can lead to death by suffocation.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 02-27-2024, 07:07 AM   #18
Oaklevel's Avatar
Sorry for off topic several years ago one of the major soft drink companies used mini vans for repairs to the soft drink machines at convenience stores and eateries.
For info at a store soft drinks at the fountain are mainly syrup, water, and CO2.
They carried a bottle of CO2 with them in the van. Hot summer, van windows closed for AC. Relief valve let go, driver died...............
Sorry involved with too many workplace deaths over the years.
1966 Mustang GT
1986 Mustang SVO
Old 02-27-2024, 07:49 PM   #19
SailorSam20500's Avatar
If you remember, CO2 that almost killed the Apollo 8 crew. Level got to the critical level and it took a MacGyver solution to adapt the LEM CO2 scrubber system to use cartridges from the command module to clean the air.
Now I need to go check on the status of my CO/Propane detector. Getting to point where it may be aging out...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
propane, replacement
