Old 10-18-2019, 12:12 PM   #1
suthunr's Avatar
rv stove igniter doesnt click as fast as it used to
TTs only a year and a half old but weve camped a good amount in it (20+times). The spark igniter used to click I would say probably two times a second and now the last couple of camping trips it clicks maybe one time in 3 or 4 seconds so its a huge difference. It still lights the oven and stove but its just strange that it would change so drastic. Anyone else experience this type of thing
suthunr is offline   Reply With Quote
Old 10-18-2019, 12:42 PM   #2
Mr. Dan's Avatar
Does it have a battery? If so, is it weak?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 10-18-2019, 12:47 PM   #3
Pull the stove top and check the wiring for the spark it may be shorting out along the way . check it to all burners common problem
MR.M is offline   Reply With Quote
Old 10-18-2019, 01:55 PM   #4
D W
D W's Avatar
From what I gather, your stove has electronic ignition. Chances are you have a button on your stove that looks like the one in the below picture? If you unscrew the silver portion you will find a AA battery. Try replacing that battery.
Name:	electronic ignition.jpg
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-18-2019, 02:06 PM   #5
Yep... needs a new battery if push button as in the photo.
Others that you push, only 'click/spark' once per push regardless.
Same with the ones you turn. One spark per click.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-21-2019, 08:32 PM   #6
suthunr's Avatar
You guys are genius! It was a AAA battery, works perfect again! Thanks yall
