Old 10-02-2017, 07:58 AM   #21
My understanding is that older bottles without the overfill valve need to have the valve replaced usually at a cost more than a new bottle would cost. I've had recert's on my trailer bottles with newer valve all ready installed for 7 bucks. They usually look to see if the bottle is rusty or dented, and put a sticker on it.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 10-02-2017, 08:16 AM   #22
Old Enough to Know Better
gasman6674's Avatar
Originally Posted by Villagerjjm View Post
I refill propane cylinders in Florida. The tanks are only good for 10 years, not 12. The law changed... At exchange points, look for the newest tanks in the batch. Some of the tanks you get may be full but they may have expired dates on them. Also, be aware that the tanks may only be partly filled... take a scale! Those tanks you call 20lb hold 4.5 gallons of propane and should weigh 40 lbs when full.
Incorrect as stated earlier DOT backed off of the 10 year requirement after an outcry from the industry. Its still 12 years after original manufacture and 5 years on a visual.
Most refill locations will not do the inspections because they assume liability. Some full dealers wont do them either for the same reason. I have a customer that will not fill motorhome tanks period, because of assumed liability.
My suggestion is to call around.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
propane
