I believe that the Suburban furnaces need to be reset after they fail to light for a few times. I believe that's as simple as just shutting it off at the thermostat, waiting a while, then turning back on.
Since you were able to restart the next morning and it worked for the next two days it sounds like that's how it works for yours.
I haven't ever run out of propane. I carry two extra tanks and a bit obsessive when it comes to making sure I have plenty of LPG before nightfall. Also added the Mopeka tank level gauge which makes it easy to see how full the tanks are. Either the LED's on the main monitor or a "percentage" on the Smartphone app.
