Old 11-29-2020, 04:34 PM   #1
Suburban water heater won’t stay lit
Hey can I ask for some help? We purchased a new Suburban SW6DE heater and after installation, it runs for about 20 secs (gets hot) then shuts down. You have to go through about 30 minutes of resetting the on off button Before it will get hot enough to take a shower. Can you please advise me as to what I’m doing wrong? Heater was self installed. I followed some posts here for installation info but I believe it is installed correctly. Thanks for your time. This is my living quarters, not a summer home. Thanks.
Coldshowerssuck is offline   Reply With Quote
Old 11-29-2020, 05:00 PM   #2
Have you checked the troubleshooting section of Suburban's manual or website?
Thermocouple?
Circuit board?
Limit thermostat(s).
Wire connections?
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-29-2020, 05:56 PM   #3
Head Rambler
Are you sure that your LP system pressure is correct at 11" WC?
Gotta go campin!
Old 11-29-2020, 06:10 PM   #4
What gets hot after 20 seconds?
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-30-2020, 04:37 PM   #5
I like his user name. The E stands for electric. Take the outside panel off and turn the switch on. It's in the lower left hand corner. Just remember to turn it off when you winterize.
05 Cummins 3500 dually 2014 Blue Ridge 3025RL
bucky53 is offline   Reply With Quote
Old 12-01-2020, 11:14 AM   #6
Wind can also be a factor. If the wind is blowing directly into the venting it can blow out the flame. If it's windy where you are, have somebody flip the switches while you stand in front to block the wind and see if it stays lit. If not then you're back to all of the troubleshooting listed above.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
heater, suburban, water, water heater
