Originally Posted by ependydad
I found ones like that on PropaneGear but worried about double-regulating the OP's grill if it has one built-in already.
In the OP, gschneider12, stated that he wanted the small tip on the hose to get the adapter. The hose in the photo shown in the OP is for low pressure RV connection which would negate there being a regulator on the grill. When gschneider12 stated "And not those little green one's", I assume he only meant that he wanted to connect his current low pressure RV hose to a propane tank larger than a 1 lb portable tank.
Now if gschneider12 wanted to replace an existing 1 lb portable propane tank with something larger, then you are correct that there would already be a regulator on the grill and you don't want double regulators.
