10-25-2021, 11:16 AM
#21
Originally Posted by SeaDog
Its not easy to find a dealer that will actually hydrostatic test a tank in my area so I paid the 25.00 for a valve reseal and visual inspection that adds 5 years I have 30lb tanks.
$25 for a valve reseal and visual inspection is about the norm. Both are included on a hydrostatic test which only takes 30 seconds.
2016 Salem 27RKSS
10-25-2021, 01:12 PM
#22
With new 20# propane tanks available for under $35 it makes little sense to me to test an old one. Even at $50 a new tank seems a better option.
-- Chuck
10-25-2021, 01:27 PM
#23
-- Chuck
Most of us are talking about 30lb or larger tanks. The 20lb tanks are easily exchangeable at any exchange kiosk before the expire date.
Scott and Liz - Southern NM
10-25-2021, 03:51 PM
#24
Just curious. The exchange tanks I've seen are plainly marked with the exchange company label/wrap.
What happens when one is away from an exchange kiosk and has to settle for a "Gas Station or Convenience Store" fill from a bulk tank? Do they just fill them even though they from an exchange company? Or are the label/wraps easy enough to remove that nobody knows?
Just curious. I know that was (and probably still is) a problem when trying to get a welding gas tank filled.
2004 Nissan Titan
10-25-2021, 03:54 PM
#25
Every place I've been will refill them as long as they are in date. I have found that the majority of exchange tanks around here have expired dates on them.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
10-25-2021, 03:59 PM
#26
At the exchanges I have used, you see many different companies tanks on the empty side, and the exchange brand on the full side. Also many exchanges are automatic (no human interface) so there is no way to check brands.
When I am filling my 30lb tanks, I watch them fill any 20lb tank from exchange or not.
10-25-2021, 04:38 PM
#27
Check your local full service propane dealer ( not a fill only place). Mine will certify an expired tank for free with a fill up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
10-26-2021, 07:48 AM
#28
"20 pound" exchange cylinders seem to contain 16 pounds of propane at the max -- I've weighed them with a luggage scale, the tare weight is on the collar.. They claim is the full rate is 80% of capacity (0.80 x 20 = 16). The actual capacity of a "20 pound" cylinder, though, is 25 pounds. Only exchange in an emergency. Hasn't been a need to weigh these in 15 years of so as there's a float valve in the tank to limit their fill.
-- Chuck
10-26-2021, 08:04 AM
#29
The typical 20lb tank weighs in at about 16 to 18 empty add 4 gal of propane at 4.24 per gallon and it gives you a full (80%) tank weight of about 33 to 35 lbs
Retired Navy
2016 Flagstaff 26 FKWS
10-26-2021, 08:07 AM
#30
TST Tire Monitors
2 100W solar panels
10-27-2021, 08:43 AM
#31
These must have been massive!  A gallon of propane weighs 4.2 pounds making each tank weigh probably 150 pounds (including the cylinder).
According to this site:
A 20 lb propane tank holds 4.5 gallons of propane and weighs 37 pounds full.
A 30 lb tank holds 7 gallons of propane and weighs 55 lbs full.
https://www.emptygrilltank.com/tank-...pecifications/
10-27-2021, 09:10 AM
#32
Originally Posted by Iwritecode
You may have missed the typo and corresponding joke in post 20. It was a joke about the typo saying 30 gallons instead of 30 pounds.
 2011 Flagstaff 831 RLBSS
If fridge is the shortened form of refrigerator, where did that "d" come from?
10-27-2021, 09:20 AM
#33
Just a heads up on "Exchange" tanks.
Prices are going up on Propane and if history repeats itself you will get even less propane in your "20 lb tank".
Here's a recent report on "Oil Prices" including Propane (which is a byproduct of the refining process):
Propane increased 0.81 USD/GAL or 124.85% since the beginning of 2021, according to trading on a contract for difference (CFD) that tracks the benchmark market for this commodity.
https://tradingeconomics.com/commodity/propane
Not only is Propane expected to get expensive, it may be scarce.
As for the exchange services, they've alredy played with tank fill amounts for pricing purposes (and profits) so expect them to consider the same again.
Look at the label for actual content. I'd expect it to be less as time goes on just like with candy bars, cereal, etc. Prices stay close to the same but you get less.
2004 Nissan Titan
10-27-2021, 09:47 AM
#34
I did miss that.
10-27-2021, 09:52 AM
#35
We have been getting less propane at propane exchanges for years. I exchange my 20lb tanks for convenience. Much easier and quicker than waiting in line at the distributor for me unless I'm also filling my 30lb tanks.
As far as scarcity and cost, nothing new these days
10-27-2021, 09:56 AM
#36
Absolutely everyone I know (including me the ONE time I exchanged a tank for my brother) simply peels off the plastic shrink wrap labeling.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 ☼ '18=49 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=90
10-27-2021, 10:01 AM
#37
And the exchanges I use don't care what the wrapper says, they will take any any brand 20lb tank.....
10-27-2021, 10:57 AM
#38
Phat Phrog Stunt Crew
The exchange tank companies had a class action lawsuit recently. They were filling 20lb cylinders at 17 lbs changing to 15lbs amount without notifying of the change in fill at the same price. So the standard fill was 17lb and now is 15lb. Bring your own tank to a refill station and get 20lb per fill up.
https://www.classactionrebates.com/s...on-settlement/
2014 Wildcat 327ck
10-27-2021, 11:13 AM
#39
Where I live, they couldn't care less whose wrapper is on the tank, but they do check the stampings for current certification. In past years several venues have been nailed by US DOT PHMSA Compliance/Enforcement for filling tanks that have expired dates on them. From what I understand there's a hefty fine if caught.
2016 Salem 27RKSS
10-27-2021, 11:54 AM
#40
As always there is a price to be paid for convenience.
Here's a comparison from Ferrellgas from last July. At the time the price for convenience was around $1.75 per gallon.
https://www.ferrellgas.com/tank-talk...etter-for-you/
For me, I pass on convenience especially with the $7 per tank extra cost stated in the article. I just fill my 20# tanks when I stop at the Distributor to have my 30# tanks on trailer filled/topped off as I leave on my trips.
I'm fortunate I guess that I have two distributors and one Co-Op nearby that I've never had to wait in line at or drive very far to.
From what I've seen at the exchanges in my area there would be a big wait to find help that could unlock the "cage" for a fresh tank. Especially after Covid.
2004 Nissan Titan
