08-06-2018, 03:02 PM
thoughts on refilling 1lb propane tanks, safe?
Hi all- I'm finding mixed reviews about refilling 1lb. propane tanks.
Is it not safe to refill-
TL
08-06-2018, 03:16 PM
I have the do it yourself adaptor to refill them yourself and have had zero issues.
08-06-2018, 03:23 PM
The only problem I have had is finding where I put the adapter. If you are prone to campsite setup or tear down errors, just be safe and buy them already filled.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
08-06-2018, 03:25 PM
https://www.walmart.com/ip/Mr-Heater...&wl13=&veh=sem
I use it all the time. easy to use and cost savings on using the 1 pounders.
You can not get them completely full. But that it not the point. Get as much as it will 'take' and use it as that.
Brother Les
08-06-2018, 03:41 PM
We've discussed before how California does have refillable one pound cylinders and according to this article, UHaul is rolling them out nationwide.
https://www.prnewswire.com/news-rele...300278688.html
I think they may have run into a problem, but can't find the details.
 2011 Flagstaff 831 RLBSS
If people could burn calories from jumping to conclusions, obesity wouldn't be a problem.
08-06-2018, 10:10 PM
The picture looks like it is the Flame King system.
08-06-2018, 10:17 PM
I know folks who have been refilling for years. About the only comment I can make is that I haven't heard of anyone getting hurt....
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
08-06-2018, 10:25 PM
Been refilling for well over 15 years. I use time and a scale to determine the proper fill weight. I'll try to dig up my instructions and pass them along. Refilling drops the cost to less than a dollar per cylinder.
m
2014 Flagstaff Shamrock 21SS
2018 F-350 Crewcab Lariat 4x4 6.7 powerstroke
Deputy Fire Chief-09-11-2026 retirement!!!
08-06-2018, 11:53 PM
I can think of a lot more ways to save a couple dollars than to refill 1lb propane cylinders. They are a grand total of $3.25 at Walmart!
08-07-2018, 07:21 AM
how many cylinders do you use annually? 10? 15? for a savings of perhaps $30 per year.....is this worth more than the risk of loosing a hand or a life? I have seen first hand what can happen when someone makes a mistake...and accidents do happen. Please think carefully about what you are doing.
2015 Flagstaff 26FKWS
Ram 1500
08-07-2018, 07:32 AM
I used to refill them and only ever ran into one problem when I unscrewed the one pound cylinder from the adapter it stayed open and slowly released all the propane not sure if it's called the needle in the bottle but it stuck.
I became concerned that perhaps some of the ones that I had refilled may have been leaking so I just scrapped the idea and started buying them at Sam's Club a 4 pack was selling for like $10-$12 and I wasn't using that many on camping trips anyway so to save a few $$$ just wasn't worth it to me.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
08-07-2018, 07:38 AM
Fully COVID-19 vaccinated
I bought an adapter hose and pressure regulator and run my small grill off a standard propane tank.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
08-07-2018, 07:40 AM
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
08-07-2018, 07:50 AM
In the days that I icefished, I used to refill them all the time since it was pretty easy to go through 3-4 a day keeping an iceshack warmed. The only issue I ever had was having one of the shraeder valves leak, occasionally. After I filled them I'd give the valve a shot of WD-40 and look for bubbles. I'd use that one on the heater and then discard it when empty. Never a problem with the refill operation though
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-07-2018, 10:44 AM
I would call that a pretty bad issue. Imagine if that is in your camper storage compartment and that happens and you don't catch it.
08-07-2018, 10:51 AM
That was one of the reasons I stop re-filling them
TST 507 TPMS
08-07-2018, 11:05 AM
Is spending time refilling the 1 lb tanks really worth saving a couple of bucks per cylinder? I usuly bring 6 or 8 with me on a 3 day camping trip and depending on how much we cook or I use the heater in the tent, we MIGHT go through 2 1 lb tanks. To me, it's not worth the money savings vs the risk of refilling them.
08-07-2018, 11:20 AM
Not as much of an issue as you try to make it, from my experience.
14K Equalizer
08-07-2018, 11:36 AM
Señor Member
Maybe someone can convince Blue Rhino they can make money if they add an exchange program for 1lb tanks.
Safer, better for the environment, etc...
2017 Forester
3051S "Bluga"
08-07-2018, 02:48 PM
You experienced leaking from the valve! So...what am I missing?
