Old 08-08-2017, 09:10 AM   #1
david_reaves's Avatar
Trouble changing 30-pound tanks?
Am I the only one that has trouble removing and replacing the 30-pound propane tanks? My Windjammer has the enclosed tanks and it is almost impossible to manage the tanks. Getting the tank in full was a real pain since there's almost no clearance. The doors are much smaller than the tanks, so rotating and twisting without straining one's back is a key skill. I've been fighting the tanks for a couple of years.
Finally, yesterday I gave up. I replaced both tanks with shorter and lighter 20-lb tanks. I had to shorten the end of the threaded rod that holds the clamp and valve. I know I'm sacrificing a third of my previous capacity. I'm gaining the ability to get the tanks in and out easily as well as almost universal availability of a spare-- even when there's nowhere to refill a tank there will probably still be a tank exchange.
I'll get some pictures later today. I didn't think about it when I was actually changing tanks.
david_reaves is offline   Reply With Quote
Old 08-08-2017, 09:16 AM   #2
Kasual Kamper
I had the 30 pounders on my '00 Mallard. Without seeing pictures of what you are talking about with your particular trailer, I can't be of much help, but I didn't find it all that problematic. You make some good points about the universality of the 20 lb tanks, but with the 30 pounders, you may only have to swap them every couple of camping seasons, depending on how often you camp. In my case, maybe three years.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 08-08-2017, 09:30 AM   #3
wmtire's Avatar
You may have to find a lot of other uses to justify the $333 price, but this could be a possible answer. I liked it being used on the ice chest.
Propane Tank Lift | Herc-U-Lifts | LP Tank Lift Macon MO
2011 Flagstaff 831 RLBSS
If people could burn calories from jumping to conclusions, obesity wouldn't be a problem.
Old 08-08-2017, 09:36 AM   #4
jeff64's Avatar
Not that big of deal. Once you get it loose, rotate the cutout in the top of the tank directly away from you and tilt it out
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 08-08-2017, 09:37 AM   #5
I suppose as we get older, the bear wrestling needed to get the 30 pounders in and out will get harder. It can be a chore for sure. For now, I just hitch the belt a notch tighter and grunt a lot!
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=90
Old 08-08-2017, 11:27 AM   #6
Here are a couple of pictures. The first is of the tanks after install. The second shows the height of the old tanks and the (lack of) clearance. The only thing I didn't measure is the size of the door opening... it is much closer to the size of the 20-pound tank than the 30. This way I won't have to lift, turn, then twist the 50+ pounds of tank & propane.
I can see that some would still prefer the larger tanks. It does give more run time for the furnace or LP mode on the fridge. That would be especially important for boon-docking. We rarely stop where there isn't at least 30-amp service, so I think I'll be happy. We often use an electric space heater to knock a little of the chill off anyway.
I'm using the AP Products/Mopeka Tank Check/ sensors & monitor/app so I will be able to easily tell if I need to refill a tank before I run out. That should help preclude the problem of running out too soon because of the smaller tanks.
ID:	147573   Click image for larger version
Old 08-08-2017, 12:36 PM   #7
Senior Senior Member
raytwntrvlr's Avatar
I've got the exact same issue. Up to now we have only used one set of tanks per year. So I just have learned to wrestle with them.
One thing... I never worry about some thief making a quick grab and run... ain't happening with this setup.
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
raytwntrvlr is offline   Reply With Quote
Old 08-08-2017, 12:41 PM   #8
I wish I had a photo of my passenger side LP compartment. It's well protected. Got a fairly significant spider web built in there. I saw the spider once right before I ran away like a little girl. He or she was big. I'll have to take care of it before our trip in a week and half. But for now that side is secure.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 08-08-2017, 12:49 PM   #9
Kasual Kamper
In more ways than one!
Old 08-08-2017, 01:11 PM   #10
rsdata's Avatar
david_reaves...
if you are close to Cincinnati I would like to take those 30# tanks off your hands for a fair price...
2014 Shamrock 183
Old 08-08-2017, 01:16 PM   #11
Georgia Rally Coordinator
aceinspp's Avatar
I have no issues removing mine from my V-lite so do not know if the compartments between the two tt are different but don't believe so. Both tt come off the same assembly line. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-18 days
Old 08-08-2017, 01:23 PM   #12
I always wondered how bad it was to remove tanks that are enclosed, then I was at the fill up station earlier this year and saw the smartest thing....
This guy pulled his RV right up to the fill up station and the attendant filled his tanks for him while they were still in the compartment.
Is there any issues with this, the guy said they do it all the time.
Im going to do this with my new xlr so I dont have to take them out.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-08-2017, 02:46 PM   #13
I have a 3001w windjammer. Tight but no problem getting the 30 lb thanks in or out. ???
Handydc is offline   Reply With Quote
Old 08-08-2017, 03:00 PM   #14
gectisme's Avatar
That device might be nice for lifting a heavy generator in and out of the truck bed too but still a little pricey.
The only issue I run into is remembering to lift the regulator and hold down bar before I install the tank, (if I refill both of them at the same time). I think I would rather have the extra capacity for now. I wonder if your doors are smaller?
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 08-08-2017, 03:07 PM   #15
I just drive up next to the filling station and have them filled where they are. No moving them big things for me. I'd find a place that can fill them where they sit.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
bshort is offline   Reply With Quote
Old 08-08-2017, 03:38 PM   #16
RSData-- Central Texas. I'll probably sell them on Craigslist. If not, I'll just keep around to use with bottle-top heaters or as larger tank for my gas grill.
Dwayne-- I had black widow spiders in my storage building one year. You can bet that they encountered substantial pesticide!
Old 08-08-2017, 03:41 PM   #17
Kasual Kamper
Don't know what's worse....trying to jockey your trailer to accessible position for fill or removing the tanks. Some of those propane places don't make it easy.
Old 08-08-2017, 04:41 PM   #18
Keystoner's Avatar
Another possibility might be Viking cylinders composite tanks. They weigh around half as much as a steel tank. https://vikingcylinders.com/shop/lifestyle/22-lb-vapor/
No I'm not affiliated with them but have used and like them.
Keystoner is offline   Reply With Quote
Old 08-08-2017, 06:23 PM   #19
We are fortunate to have a place where you can just drive your trailer thru and have the tanks filled without having to remove them.
Harris85 is offline   Reply With Quote
Old 08-08-2017, 06:55 PM   #20
CaptnJohn's Avatar
I'm 69 and broke my back in '68 so the 30#ers are a problem. The only help I've found is CW. One I can pull up to and have tanks filled without removal. The other location requires removal but will have someone remove and reinstall (I provide a nice tip here). The propane price is competitive with others in the area and they give a 20% discount on Tuesday and Wednesday. I'm generally in one of those once a year and always have at least 3/4 of 1 tank left.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
tank
