06-13-2021, 08:15 AM
#41
Originally Posted by JesseC1006
How to I pull the board? Or look at it?
What is the make and model of ur WH?
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
06-13-2021, 09:22 AM
#42
It's a Suburban as told in the OP.
Good Morning Everyone,
So I have a brand new 304BH with the suburban water heater.
It should be either a SWDE or SWDEL model since the Op also stated they have an electric function:
I don’t have one. But I am sure someone else in the campground does. I’m pretty sure its getting power. I attempted to fire once the other day. And ran for a bit. But stopped so I assumed it was up to temp. I did have the electric on as well. Faster recovery time in the am when two of us are getting ready for work. But it never kicked back on after that.
 2011 Flagstaff 831 RLBSS
If fridge is the shortened form of refrigerator, where did that "d" come from?
06-13-2021, 10:53 AM
#43
54 Years, 13 RV's
On the back of the WH are a bunch of wires leading to a plastic box. The box is either taped to the WH or screwed to the wall. Pull the cover off of the board and look for burned spots near the middle of the board.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
06-13-2021, 10:55 AM
#44
It’s gonna be quite a project to get to the back of the water heater. It’s under my bed and it’s not easy to get to.
06-13-2021, 11:22 AM
#45
54 Years, 13 RV's
Work or not, it will most likely solve your problem. You or an expensive RV tech.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
06-13-2021, 11:44 AM
#46
 This is what mine looked like after one week.....
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
06-13-2021, 11:55 AM
#47
Wow. Guess I gotta look and pull the board out.
06-13-2021, 11:59 AM
#48
X2.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
06-13-2021, 12:00 PM
#49
Originally Posted by Mr. Dan
X2.
It’s a shame I can’t get the dealership to help me. I’m gonna be making a call to the manufacturer soon!
06-13-2021, 12:30 PM
#50
See if you can find a local Independent RV Repair facility.
You can probably get FR to allow you to take it to them for the repair. You will just have to pay up front and then wait for reimbursement from FR.
Just an FYI, I think the control board is o the back of the WH so you will need to look for the access door to get to the back without actually removing it.
06-13-2021, 12:56 PM
#51
The water heater is in my storage compartment behind a little divider. I sure as hell ain’t fitting in there.
I can get to the back of it from under the bed. But hard to do by myself. I’m waiting for my gf to return from AC
06-14-2021, 11:16 AM
#52
Read my post more carefully, I Did Not tell yo how to get at it, I simply informed you where it was located on the WH itself. How you get to it is your business.
Is it possible to remove the mattress and then lift up the plywood underneath and access it from above? You may have to remove a few screws but that beats the alternative, it seems to me.
(There, NOW Ive made a suggestion on how you might gat at it)
06-14-2021, 12:01 PM
#53
HA HA thanks man. Yeah getting at it from under the bed shouldn't be an issue. Might be a little tight but easy enough. My bed doesn't have the gas shocks on it so I need help. I camped by myself this weekend so I had to wait regardless. I might attempt it tonight.
06-14-2021, 02:18 PM
#54
Best of luck with you issue.
Its amazing where and how FR locates some of the components of the TT.
My heater failed and needed repair. Simple right? Just go outside and open the door and pull out the heater and fix it. NOPE.
Heater is inside under the fridge on a platform. Now the unneeded platform causes the heater to be too high to be pulled out of the hole. The premise is to remove the fridge to get to the heater.
Anyways, just another showing that TT manufacturers have never camped a day in their lives cuz if they had they would not build TT's in this manner.
Either that or they are having engineers making the designs. Always looks great on paper but in real life, not so much. LOL
2019 Forest River Coachman Freedom Exp 248 RBS
Jeep Grand Cherokee pulls like a dream.
First trip, 10K. Delaware to Del's Restaurant at the top of Route 66 to California, back to Delaware without a hitch or glitch. Living the DREAM!
"Brain Farts sometimes go unnoticed until further Inspection "  If they only had a smell.
06-14-2021, 02:44 PM
#55
I have worked with many engineers like that, fortunately I had some good mentors who encouraged me go talk to the machinists and the assembly technicians often. I learned quite a bit about being a “good design engineer” from them.
IMO, every engineer should spend time on the shop floor and in a repair shop, especially early in their career.
06-14-2021, 03:03 PM
#56
I should have said some engineers. As with everything not all are bad or good.
Could you design a TT for me that is functional and will be easy to maintain because it was designed with the future in mind? LOL
Thanks for the reply.
06-14-2021, 03:13 PM
#57
Water Heater Issues
(Based on my camper I think they employ more of the “bad” than “good”)
I sure could… but the bill would give you a heart attack  and then you would need to find someone to build it.
What we really need is a Tardis Travel Trailer, one that is “bigger on the inside!”
06-14-2021, 03:30 PM
#58
Water heater is warranted by Suburban, not Forest River, so anyone can fix a warranty issue. Your dealer is busy selling trailers and can maybe get to you about Thanksgiving.
Not sure the panic or even the use of the water heater on propane. These work just fine on 115AC power. Yeah, I want mine to work on both sources but if I'm on shorepower I don't need to be burning gas.
-- Chuck
06-15-2021, 06:39 AM
#59
Talked to Forest River yesterday and they are willing to send me the part I need. Honestly no questions asked really. Kinda surprised me to be honest. I have yet to determine if it is in fact the board itself.
And I get what ya mean while on shore power. I do use electric now. However when two people shower in the am before work the recovery time is very fast when gas is on as well. Its more about that. However my GF is off for the summer (Teacher) so its just me now. Less to worry about.
But with all that said it is brand new and it would be just nice if everything worked.
-- Chuck
06-15-2021, 06:44 AM
#60
Thanks to everyone who replied to this thread! There might be light at the end of the tunnel for me.
I talked to Forest River yesterday and they gave me a couple of options. The first one was to call "SafeRide" I believe. Mobile RV techs. I have a flyer in my paperwork somewhere at home. I then mentioned that there is an RV dealer close to me who carries some other Forest River Models. The girl on the phone said basically they would reimburse me for whatever as long as there are photos and documentation and all that stuff. The water heater isn't my only issue right now so. However that seems to be an easy fix if it just the board. Might pull it out Friday before I leave for vacation (not with the camper)
But again thanks all! Awesome to see a great group of people helping each other out!
