Old 09-10-2021, 09:15 AM   #1
Miles to go
Gargie's Avatar
Wolf pup heater issues
2021 wolf pup with suburban heater of course. Starts up and runs but most of the heat seems to be coming out the exhaust vent outside! There is some heat coming inside but not as hot as what is being exhausted! I'm curious if this is happening to everyone and it's just the way this thing works. Wouldn't be surprised.
Gargie is offline   Reply With Quote
Old 09-10-2021, 11:41 AM   #2
Exhaust temp is always way higher than the inside vent temp. What you are experiencing is normal.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 09-10-2021, 12:47 PM   #3
bikendan's Avatar
Yep, RV furnaces are not very efficient.
Old 09-11-2021, 08:50 AM   #4
Miles to go
Gargie's Avatar
Yeah Im just figuring that out. It's absolutely crazy because if you turn the thing around and have the exhaust heat coming inside the trailer it would heat the thing up in like 2 minutes flat! Oh well, it is what it is. Thanks for your reply.
Old 09-11-2021, 01:41 PM   #5
Uhh...yeah
Uhh...yeah, but it would also fill up the inside with carbon monoxide, carbon dioxide, water vapor, and other unhealthy combustion products.
The design is pretty simplistic. There are two separate, completely isolated air circuits. A single motor with a squirrel-cage impeller on each end forces air through both circuits.
Air comes in one of those two outside vents and is mixed with propane and ignited inside an enclosed "firebox." The combustion products are exhausted out the other vent.
Air comes in the interior furnace return grille to a "plenum" which surrounds the firebox. The air is warmed as it passes over the firebox and then forced through the vents.
This is really the same scheme as the gas-forced air furnace at your house. Because of the space constraints in an RV, the heat exchange is a lot less efficient.
Larry
Larry-NC is offline   Reply With Quote
Old 09-11-2021, 05:16 PM   #6
jeff64's Avatar
Yup, that and the carbon monoxide!
Sent from my SM-G930T using Forest River Forums mobile app
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 09-11-2021, 05:23 PM   #7
Check your ducting . could be many places where heated air is lost and not making it to inside the trailer . they use cheap drying hose lose lots of heat and flow .
MR.M is offline   Reply With Quote
heater, wolf pup
