Old 07-04-2021, 09:10 AM   #1
2nd AC unit - outside odors being pulled in
Hi all,
We have a 2020 Fredom Express LE with a second AC unit in the main bedroom area. We've found that when it is on it pulls in outside odors quite proliferically. I normally wouldn't mind, but when at a rather tightly packed campsite and people using a lot of lighter fluid, it can be quite noxious. It's a dometic unit that doesn't have the option to pull outside air (full recirc-type). When I examined the unit, it seems to not have a good and solid seal to the roof. in fact the metal plate that is bolted to the roof does have some up and down movement.
I used some incense around the base of the unit and sure enough the smoke is sucked into the unit quite readily. I attempted to use some of that aluminized hvac tape to seal around the base of the unit as well as any seams that appear to have air infiltrations as well, but our past camping trip had the same issue. I'm guessing the tape lost it's adhesion due to the movement during towing.
I took it to the dealer before trying any self-repairs for the issue and of course they couldn't find any issue. The unit is now out of the 1 year warranty as well.
Should some kind of butyl tape be used underneath the whole unit? I couldn't find whether that should be the case or not. I'm pretty handy so not afraid to remove the unit in full to figure out what's going on or to resolve it more appropriately.
Suprnova74 is offline   Reply With Quote
Old 07-04-2021, 10:53 AM   #2
6speed's Avatar
Air conditioners on RVs have a 2 year warranty. At least the ones Iíve owned have.
6speed is offline   Reply With Quote
Old 07-04-2021, 06:09 PM   #3
The actual AC unit may have the warranty, but unsure if something like the installation is considered a part of that warranty. Also, there isn't time available before my next trip so would like to try to resolve it beforehand if possible.
Old 07-04-2021, 06:24 PM   #4
Flybob's Avatar
There should be a compressible seal between the external base and the roof. There are several adjustable screws that are used to tighten the base against the seal and the roof. You want to partially compress the deal but not too tight. You may need to remove the inside face as the screws are tightened from the inside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-05-2021, 06:16 PM   #5
What Bob says
What Bob says^^^
It's a foam gasket between the air conditioner and roof. Remove the inside cover and tighten the screws snug, but no further, from the inside.
Larry
Larry-NC is online now   Reply With Quote
led
