Old 11-24-2014, 08:42 AM   #1
All of the seams in the walls (corners, and crevices) seem to be sweating
All of the seams in the walls (corners, and crevices) seem to be sweating- there's water beading up in the corners and running down the wall- it's not raining, any ideas? 2012 surveyor
trailerwife is offline   Reply With Quote
Old 11-24-2014, 08:47 AM   #2
Rrickim63's Avatar
Condensation, when the heat is on. What's the outside temperature? What temp is the heat set
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 11-25-2014, 01:02 PM   #3
Temp outdoors in the morning (which is when it usually occurs) is usually upper 30's n heat on like 70 inside- is it normal for the walls to do that? Or corners?
Old 11-25-2014, 01:28 PM   #4
The corners are where the insulation is usually the worst, if it's insulated at all.
When I bought my house 35 years ago, I had ice building up in the corner of my family room. After a few years, I pulled the paneling and found they had put NO insulation in the corner. Builders are either lazy or just shoddy.
2011 Traverse LT, 3.6L, FWD
Old 11-25-2014, 02:08 PM   #5
Buy and use a big dehumidifier. In the mean time, open vents and run fans
donniedu is offline   Reply With Quote
Old 11-25-2014, 04:58 PM   #6
Rrickim63's Avatar
X2
2006 Roo 23B hybrid
2006 Ford F150 4.6L
