Old 09-26-2020, 05:33 PM   #1
Bathroom vent motor substitute
On my third bathroom vent motor since i purchased my trailer new in 2012. Went to the store and got a replacement 40$ . Came back to the trailer and found these on ebay. Looks like same motor but is missing splines on the shaft. Any ideas how to bypass that? Tried searching for the whole part number thats on original but couldn't find anything. RS-385 is the one from china, and the original has same number.Click image for larger version
ID:	240030Click image for larger version
ID:	240031Click image for larger version
Kuba is offline   Reply With Quote
Old 09-26-2020, 06:24 PM   #2
TowPro's Avatar
that does not look like the same motor to me. the one in your hand is pretty much sealed, the one in picture is very open. the van in the bathroom vent is a wet location. Most times a drop of oil on ends of motor shafts and a little forcing until they are free again fixes them for a while.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 09-26-2020, 06:41 PM   #3
Head Rambler
Can you take a picture of the entire motor?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-26-2020, 06:47 PM   #4
zs325RES's Avatar
You might be better off installing a better vent fan assembly with a brushless motor. Those can run much longer, unlike those cheap brushed motors. Cheaper in the long run too.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 09-26-2020, 07:00 PM   #5
rsdata's Avatar
My trailer is new May 2014... I just cleaned my Maxx-aire fan for the third time... Fan still works great, but running it for long periods of time to just draw air into the camper sure makes that fan and fan parts grimey.
I take the shroud off from the inside, take the fan off the shaft, then clean all of the parts that are exposed. It is still quiet and still works well. I don't think I would have the patience to replace the motor, but to each their own.
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 09-27-2020, 07:54 PM   #6
fan model number????
Thats a great testimonial for your fan. What model of fan do you have? I would like to purchase the same model.
TIA
Richard
OTE=rsdata;2421707]My trailer is new May 2014... I just cleaned my Maxx-aire fan for the third time... Fan still works great, but running it for long periods of time to just draw air into the camper sure makes that fan and fan parts grimey.
I take the shroud off from the inside, take the fan off the shaft, then clean all of the parts that are exposed. It is still quiet and still works well. I don't think I would have the patience to replace the motor, but to each their own.[/QUOTE]
Richy R is offline   Reply With Quote
Old 09-27-2020, 08:16 PM   #7
rsdata's Avatar
TIA
Richard
I don't have the exact model number, It came stock with the camper, two of them, and after this many years they may not even make the exact same one. However I looked up Maxx aire on amazon and came up with the same brand, basic 3 speed fan.
Last time I bought this type of fan in 2015, I installed it in the roof of my Dodge 350 van I used as a Tow vehicle. I don't believe I spent more than $90 back then.
I hope this helps you.
2014 Shamrock 183
Old 09-27-2020, 09:03 PM   #8
That is a great testimonial for the fan you have. What model is it? That's the one I want to install in my coach.
TIA
Richard in Milwaukee
Old 09-28-2020, 09:45 AM   #9
More pics if stock motorClick image for larger version
ID:	240129Click image for larger version
Old 09-28-2020, 10:37 AM   #10
yes that helps
in helping to in helping to make a decision as to what I replace my stock cheesy motor exhaust exhaust fan.
QUOTE=rsdata;2422358]I don't have the
I hope this helps you.[/QUOTE]
bathroom, roo, vent
