10-12-2020, 02:12 PM
Papi
Black Jack coating over rubber roof? Pros/Cons?
I have a 2013 Cedar Creek fiver. The roof is showing signs of wear (no leaks however) and when a repair guy recently pressure washed the roof he suggested it may be time to protect the original roof covering. He uses Black Jack 1000 (Lowe's) and says it will last up to ten years.
My questions are: (1) is this coating acceptable for the entire roof, (2) does it protect edges from moisture ingress, (3) may you recoat with Black Jack in a few years, and, (4) are there any downsides to doing this in the first place?
We are permanently parked in a Florida park so we're not bumping and thrumping down the road anymore. I'm not too concerned about the 10 year thing. If I had to do it again in 4 or 5 years I'd be happy.
Thanks for all ideas/comments!
PapiCamper
We're Fulltime in the Cedar Creek
and it ain't goin' nowhere. On 7 years
now in same place.
10-13-2020, 08:58 AM
Here's what the mfg. data sheet says about it.
PRECAUTIONS:... Do not use on EPDM, TPO, PVC or other rubber/synthetic surfaces....
I'm not sure I'd trust it on an RV roof.
Gotta go campin!
10-13-2020, 09:22 AM
Papi
Thanks for heads-up bama. Guess I'll go read the fine print at Lowe's. Wonder what any alternatives might be.
PapiCamper
now in same place.
10-13-2020, 11:04 AM
We have had good luck with Crazy Seal system, and Gaco has one very similar that another member used. You can get a complete kit that has cleaner, sealing tape, sealer, and final coat. If your roof is clean and in good shape, the final coat might be all you need.
https://crazyseal.com/?gclid=Cj0KCQj...YaAgmfEALw_wcB
https://gaco.com/new-solution-rv-roof-restoration/
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
10-13-2020, 12:26 PM
Papi
Bama: On closer inspection (at Lowe's) the 5 gallon pail specifically says it's "great for RV rubber roofs...". I'm not sure what product you may be looking at. I checked the mfgr. spec sheets on what I'm using and they also said it's okay for everything except asphalt roofs.
The product I'm looking at is:
Black Jack® ETERNA-KOTE® 100% Silicone Roof Coating
Is this the same one you referred to?
Thanks.
PapiCamper
now in same place.
10-13-2020, 12:42 PM
My 2005 epdm roof is still in good shape. If I keep it much longer I will look at a company like Dicor who specializes in rv roof coatings.
A properly maintained epdm, tpo, fiberglass, etc roof should last a lot longer than 7 or 8 years.
Wouldn't ever pressure wash my roof.
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
10-13-2020, 12:48 PM
The one I got that info from is the Elasto-Kool 1000. That's the one I found on the Lowes site, which is the place they mentioned.
I see they also sell the Eterna-Kote, but it doesn't have the '1000' designation attached to the name.
Gotta go campin!
10-13-2020, 03:46 PM
Another option maybe Henry Tropi-cool, can says for RV rubber roofs and mobile homes etc etc
