10-03-2014, 04:47 PM
Camco/ maxxair vent covers
Will a common camco or maxxair vent cover work with a power/automatic fan-tastic vent or will it damage the gearing in it? has anyone tried it with success?
10-03-2014, 04:52 PM
I just put a MaxxAir II vent cover over our power fan. We now leave the fan cover open all the time. No issues.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
10-03-2014, 06:00 PM
Canadian Member
The MaxxAir Fan/Mate is made for high volume fans like the Fantastic Fan. The MaxxAir II is not but some do use it. I installed the Fan/Mate on our Roo and it worked fine but the cover on the Fantastic Fan itself couldn't open completely with the Fan/Mate installed. It didn't affect the airflow though.
The standard MaxxAir is 9" high. The MaxxAir II is 9.5" high and the Fan/Mate is 10" high.
10-03-2014, 07:05 PM
X2 Have them on both vent fans (including a fantastic fan) and we love them.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
10-03-2014, 07:38 PM
We have vent covers on everything, with the exception of the shower skylight. Vent covers should IMO be mandatory on RVs, they keep the weather out even if you forget to close your vents, and most campers have done the forget thing. Another issue is hail, wind, and tree branches.. if you have vent covers you have the first /initial line of defense, without them.. you better have a roll of poly, duct tape, or a tarp.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
10-03-2014, 08:12 PM
I had a leak in my bathroom vent. When I tried to take the vent cover off (fantastic vent w. Fantastic vent cover), it had gotten stuck in the sealant around the vent. In the process of wrestling with it, I put a small tear in the roof, so I had to fix that as well. Got the leak fixed and decided to leave the cover off altogether. I am not impressed with how the vent and cover were installed and sealed. I suppose if I get ambitious, I could clean up the old sealant and do it better.
Sent from my KFSOWI using Tapatalk
10-05-2014, 08:27 AM
Biggest advantage IMO of the vent covers is being able to leave the vents open to prevent condensation. We have a Camco cover on our non-powered vent and a Fan-tastic cover on our bathroom Fan-tastic fan. Both stay open all the time, even on the road and in winter storage (its also covered in the winter). Never had any issues with rain blowing in or condensation in the bunk ends. The bathroom fan runs on low speed most of the time while camping, and pulls a little air through the unpowered vent.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
10-05-2014, 08:44 AM
Maxaire Fanmate is what the dealer told me to use over the fan.
Think about things before you do them make life easier not harder.
10-05-2014, 10:01 AM
Yes, the "Camco" air vent covers do fit over and allow the vent hatch to open wide enough for good flow. Easy to install.
I installed 3 covers on my rig and I also did the upgrade of adding a switch to include "reverse" flow.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
10-05-2014, 10:11 AM
Slight theft of thread: Do those of you with vent covers leave the vents open or closed when you put on your trailer cover for the winter?
2011 Traverse LT, 3.6L, FWD
10-05-2014, 12:10 PM
I suppose it depends on what you call 'winter'
.... in the Pacific Northwest we get a wet winter and some snow, not the 5 to 6 feet of snow as some might think.
I used a full cover on my previous 5th wheel and only left 1 vent "slightly" open...just a crack.
Here ..the winter temps do dip below freezing so I always left a heater inside that would come on at 3 to 4 degrees above freezing.
Also when the trailer is closed up for the winter I leave a "Stor-Dry" unit running. It combats mold, mildew and dampness by circulating the air with a 'low' heat continuously....fan and heat element draw 90 watts.
I did all this to combat any moisture problems and it seemed to work.
However, if your 'winter' is in a area of temperatures that do not go below freezing... I would definitely want to leave all the roof vent open a certain amount for air circulation.
-Islander-
10-05-2014, 12:40 PM
Bill
X3 the other is a waste of money in my opinion
2011 GMC 2500HD Diesel
10-05-2014, 03:59 PM
Open. And we do get well below freezing here in central Indiana.
2013 Roo 183
10-05-2014, 07:26 PM
Should have also mentioned that I have no power available while in storage. Also no maxxair cover, so I'd have to put a 2x4 or something under the vent cover before installing the ADCO cover.
10-08-2014, 09:52 AM
In our area on the SW Alberta prairies, it's dry, dusty, and windy. I keep my vents closed in the winter, and have never had a problem with condensation. If I left them open even a bit, we'd have a layer of fine dust everywhere, and then I'd have to deal with a mad wife.
10-09-2014, 10:58 AM
We have the vent covers over all our vents and leave them open while at home but I close them while traveling just to help keep the dust down inside.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-09-2014, 04:15 PM
I installed the MaxAir 11's on all our vents, 2 powered and 1 not...no issues and an easy install....other than being able to keep vents open, it also helps to protect the factory vent covers...plus helps keep some sunlight out.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
10-23-2014, 08:20 PM
[QUOTE=Islander;714107
-[/QUOTE]
Do tell what is a stor dry?..
2015-26days, 2014-32days,
2013-33days, 2012-30days
10-24-2014, 08:55 AM
The "Stor-Dry" ( Click for web link) is a 110 volt small low power draw fan/heater.
For my size of 5th wheel I should have 2 Stor-Drys running, but as mentioned (above) I have another heater set to come on at just above freezing temperatures.
In warmer climates perhaps the Stor-Dry is not necessary when unit is stored.
Hope this helps.
-Islander-
10-24-2014, 09:36 AM
Denver, CO
I take my create a breeze cover off entirely for the winter so the camper cover fits better. I like the create a breeze vent cover cause it has a high flow rate (according to their tests) and it pop's right off with 4 clips.
It's called Fan-tastic Ultrabreeze Vent Cover and it is a little bit more $$$ as any higher quality product would be.
2017 Fuse 23T
