Old 04-04-2021, 11:09 PM   #1
Caulking
Hello. Happy Easter to all. I have a question. Does anyone know what kind or does it matter the caulking on roof around air vents and ac unit. Does it need to be a certain brand. I cleaned off roof and notice some caulking cracks I would like to fix Thank you
gschneider12 is offline   Reply With Quote
Old 04-04-2021, 11:46 PM   #2
I would suggest Dicor self leveling caulk. You just run a bead along the caulk you have now and it self levels. Pretty nice stuff if you ask me
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
RobRockz is offline   Reply With Quote
Old 04-04-2021, 11:50 PM   #3
LittleBill's Avatar
Welcome to the forum.
Use Dicor self leveling lap sealant on all parts of the the roof. Use Geocel on sides. Never use silicone caulking anywhere. I have also used Eternabond tape first in addition to the Dicor.
https://www.amazon.com/Dicor-551LSW1...s%2C203&sr=8-5
https://www.amazon.com/s?k=geocel+23...s_ts-doa-p_7_9
https://www.amazon.com/EternaBond-RS...s%2C199&sr=8-3
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 04-05-2021, 12:01 AM   #4
Thank you
Old 04-05-2021, 12:10 AM   #5
Thank you
This stuff right here is what you want for your roof.
https://www.amazon.com/Dicor-501LSW-...omotive&sr=1-2
Old 04-05-2021, 12:15 AM   #6
Wow. U even gave me a link. Thank you very much. Have a great night
Old 04-09-2021, 09:50 AM   #7
Lestienner's Avatar
Use the self leveling on flat stuff and non sag on vertical stuff... both available on amazon
2015 Grey Wolf Limited CCKT26DBH
Lestienner is offline   Reply With Quote
Old 04-09-2021, 10:20 AM   #8
robo44's Avatar
I just wanted to add, as other may read this too and assume Dichor is the sealant for all cases.
Although probably not the case for the OP, you should make sure your roof material is the MFG preferred sealant & can accept Dichor. Dichor is excellent and for most RVs and Trailers you will have no issues.
I have a fiberglass roof , Dichor does not stick to my FR3 Roof. Yes it does seal but I can peel it off with my finger's in once piece even after cured. MFG requires Heng's 95502 White NuFlex #311. For some reason that stuff is a bit different in chemistry and will not simply peel up.
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30 [/B]
robo44 is offline   Reply With Quote
Old 04-09-2021, 12:48 PM   #9
Pseudonym
BrandonSmith's Avatar
I'm a newbie. Why not silicone?
2021 Shasta 18FQ
2017 Ram 1500 Lone Star Crew Cab 5.7L HEMI
Attachment 251949
BrandonSmith is offline   Reply With Quote
Old 04-09-2021, 12:51 PM   #10
robo44's Avatar
Im sure there are more reasons but It will damage the rubber roofs, not UV protectant and will disintegrate quick
Days Camping
Old 04-09-2021, 01:20 PM   #11
bikendan's Avatar
You should have roof maintenance paperwork in your owners packet. Read that for proper caulking and cleaning instructions. NEVER silicone.
Old 04-09-2021, 08:52 PM   #12
Pseudonym
Thanks. Iím aware of the roof, it was the previous post I quoted said never use silicone on anything that piqued my interest considering there is silicone caulking inside my camper.
Old 07-07-2021, 07:39 PM   #13
OKHerbie's Avatar
The Forest River manual for my 2017 FR3 30DS says that I have a Superflex roof and that only sealants from Alpha can be used on it. That stuff is not easy to get in Canada and very expensive. Has anybody dared to use Dicor on a Superflex roof? What happened?
Herbert & Inge, German Pinscher Codicayoti,
2017 Forest River FR3 30DS,
2016 Ford Edge AWD 3.5L
Cheers from the top of the Okanagan
OKHerbie is offline   Reply With Quote
Old 07-07-2021, 07:45 PM   #14
rsdata's Avatar
Try Eternabond tape for sealing the roof...
it sticks to everything and will last a decade or more... no more caulk that dries and shrinks and peels off...
http://https://www.forestriverforums...nce-90060.html
EternaBond
2014 Shamrock 183
caulk
