Originally Posted by Tlmgcamp
I have Azdel exterior wall panels on my TT. Has anybody tried an off-the-shelf ceramic car wash or wax? I am trying to make those black streaks easier to clean
For what it's worth, Azdel is a fiberglass-based composite insert that replaces wood/luan INSIDE the wall sandwich. Its main benefit is being unaffected by water, so no swelling or mildew and less risk of delam, while being half the weight. Your Apex Nano has a fiberglass exterior.
Ceramic coating and wax both serve as a sacrificial layer that - among other things - DO help make surface dirt (including the dreaded black streaks) easier to remove. Some waxes also contain a polishing element that help remove stains and oxidation as the wax is applied and then buffed.
Black streaks, left unchecked or unaddressed in quick order can become much, much more difficult to clean off.
Here's an old RV 101 video that holds true almost a decade later:
I'm a fan of modern cleaning chemicals. There are a million of them, and some do better than others, considering what is making your particular streaks. Black streaks and related stains are generally an amalgamation of organic material, surface dirt and oxidation, and can be fairly different from place to place around the country. Likewise, RV's that spend more time outside and uncovered fall victim to black streaks more rapidly than those that are stored covered or indoors. If you find something that works well for you, keep using that.
I like Starbrite products, and have used them with satisfactory results on boats and RVs. Likewise, I am a big fan of 303's chemicals and am looking forward to receiving their black streak remover to put it up against favorite Starbrite. Lastly, I've also recently heard good things about "LA's Totally Awesome."
Again, there are commonalities, but not all black streaks are the same.
Just my .02. hope this helps.
