Old 12-07-2019, 11:08 AM   #1
Delamination on Flagstaff
The nose on right front corner has a bubble about 8" wide x 2' running up and down. Is this fixable without major repair and if so how? Thanks
ID:	220246   Click image for larger version
ID:	220247   Click image for larger version
Bill Roper is offline   Reply With Quote
Old 12-07-2019, 11:17 AM   #2
Bill,
Please post a photo if possible so we can see what you are asking about.
Hard for us to comment on something you are seeing but we are not.
Also give us your make and model... or better yet, go to your user control panel and set up a signature line so that info is available. I went to your profile and found nothing.
We can't help you if you don't help us.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 12-07-2019, 01:26 PM   #3
Thanks for adding some photos.
Too bad they seem to be sideways.
If that delam is on the sidewall towards the front cap seam, that is typically caused by water intrusion around the seams.
How are they?
Have you touched up any cracks/gaps on a 2012 model?
Old 12-07-2019, 01:59 PM   #4
Lots of You Tube how to videos if you google "rv delamination repair". At best this is a BandAid fix for the real problem of water leaks causing wood rot of the Luan (Lauan?) which causes the release of the Filon siding.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
flagstaff, delamination
