Old 03-04-2021, 11:08 PM   #1
Dicor needed for solar panel bracket?
Hello. I installed some solar panels using the standard z-bracket with two screws on each into the roof. I put a strip of butyl tape under the bracket before setting it on the roof. The screw goes through the butyl tape. I covered the screw heads with Dicor self-leveling sealant.
Do I need to run a bead of Dicor around the foot of the bracket, or is the butyl tape enough?
If I need to use Dicor, can anyone suggest how to get the Dicor on the back edge of the bracket, under the panel? There's only an inch of space and I don't think I can get the Dicor nozzle in far enough under the panel to seal the edges completely.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 03-04-2021, 11:24 PM   #2
I would put Dicor on any seem that potentially could be a place where water could intrude. You cannot have enough Dicor. I used a piece of 3/8 rubber fuel line and slid it on to the Dicor tube then gorilla tape so it can't come off. The fuel line could then be used to reach the back of the mounting bracket. I used about a 12 inch piece so it was easy to bend under the panel to reach where I needed the Dicor. Worked for me, there might be a better solution.
Lundy is offline   Reply With Quote
Old 03-04-2021, 11:30 PM   #3
These will work...
https://www.amazon.com/dp/B074MCD2Z5/
SmackIt is offline   Reply With Quote
Old 03-05-2021, 10:21 AM   #4
Originally Posted by SmackIt View Post
Thanks. I didn't know such things existed.
Old 03-05-2021, 10:22 AM   #5
Originally Posted by Lundy View Post
... I used a piece of 3/8 rubber fuel line and slid it on to the Dicor tube then gorilla tape so it can't come off. The fuel line could then be used to reach the back of the mounting bracket. ...
Hmm... I can get that today. Good idea.
Old 03-05-2021, 10:30 AM   #6
put on rubber glove, apply to finger, smear along edge.
rubber glove is optional
2023 Coachman Apex UL 243FKS, 2016 F150
Underthedog is offline   Reply With Quote
Old 03-05-2021, 02:29 PM   #7
DogFather's Avatar
If it's not too late or inaccessible, I'd back out the screws and inject a gob of Dicor into each screw hole, then replace the screws.
John, KA6CHX
2018 FR Berkshire 39A
DogFather is offline   Reply With Quote
Old 03-05-2021, 02:35 PM   #8
robo44's Avatar
Agreed x2
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
robo44 is offline   Reply With Quote
Old 03-05-2021, 03:04 PM   #9
Dahagen
X2. You can never use too much Dicor.
dahagen is offline   Reply With Quote
Old 03-05-2021, 03:47 PM   #10
"Curmudgeon"
Send a message via MSN to Trawlerphil Send a message via Yahoo to Trawlerphil
I'm an EternaBond fan boy, but Dicor will work, even if it is a copper pipe in a PEX world.
https://www.amazon.com/EternaBond-RS...4977174&sr=8-3
_____________________
TrawlerPhil
2014 Flagstaff Classic Ultralite 8528RKWS
2018 F-150 4X4 Max tow EcoBoost 3.5
2020 Tesla Model Y
Trawlerphil is offline   Reply With Quote
Old 03-05-2021, 05:49 PM   #11
I do this plus make a bed of Dicor between the roof and the bracket. After screws are installed cover the screw heads with Dicor.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 03-05-2021, 07:33 PM   #12
That poses the same question: How do you apply it on the back side of the bracket? It's not flat. Do you fold it up and sandwich the bracket between another piece folded up on the outer side?
Old 03-05-2021, 07:38 PM   #13
On the inboard side of the panel I used well nuts and put Dicor in the hole before inserting the well nut. Some squished out and formed a donut around it.
As for a bed of Dicor, I used a strip of butyl tape. It's well-squeezed between the roof and the bracket. That being the case is why I asked about Dicor. Does the butyl tape not provide waterproofing? Is it not as reliable?
Knowing that water could seep down the shaft of the screw, I did cover the screw heads with Dicor.
Old 03-05-2021, 07:38 PM   #14
Originally Posted by robo44 View Post
Agreed x2
I did that during installation.
panel, solar, solar panel
