Others have used the Hengs Vortex I or Vortex II. The Vortex II can draw air in or reverse to exhaust out. It is sold on Amazon. Some have used the RVLOVENT brand. They are both installed from inside, no need to remove the vent from the roof.
Just check the size to be sure they will fit. They're 12V. You can watch installation videos by people who installed them. In the living room, if there is a vent, you can remove the trim piece and look to see if there are wires stuffed up in there. Make sure to check which is the positive wire.
This is the link to the RVLOVENT:
Upgrade Kit Rv Trailer Camper Van Roof Vent Fan Motor Replacement, Compatible with Heng's, Ventline
https://a.co/d/c0KZ85M
This is The HENGS:
https://www.amazon.com/Vortex-Ii-Ven...17C0RLP2&psc=1
