Old 07-16-2020, 01:54 AM   #1
rocketman1083's Avatar
Geocel Proflex RV sealant
I replaced my vent with a Maxxfan last and when I went to caulk around it I found out I didnít have any dicor lap sealant (thought I had everything I needed before I started) and needed to caulk it up as rain was possible overnight. I used Geocel Proflex RV sealant for the gap between the fan and the roof. I have come to find out that it shouldnít be used on my TPO roof after I finished the install.
Anyone have any idea what problems I may be in for? Itís been on for about 10 hours so far. Should I remove it all? Have I messed up my roof membrane already?
Any help would be greatly appreciated!
Bob
2015 Dodge RAM 1500 Laramie w/ 4 Corner Air Suspension, 3.92 gears, 32 gal fuel tank, integrated brake controller
2016 Coachman Freedom Express Liberty Edition 320 BHDS
rocketman1083 is offline   Reply With Quote
Old 07-16-2020, 02:21 AM   #2
you are ok with it.
cfo111 is offline   Reply With Quote
Old 07-16-2020, 02:33 AM   #3
Originally Posted by cfo111 View Post
you are ok with it.
Thank you for the quick reply. I was worried I might havenít damaged my roof when I read it wasnít compatible with TPO.
Old 07-17-2020, 06:52 AM   #4
So I had a chance to call the company that makes the geocel Proflex RV sealant. He said there wasnít any risk to damaging the roof membrane from my install. The problem was that the Proflex doesnít bond to TPO or EPDM roofing and it wonít seal as expected. So I think Iím just going to seal the unit with 4 inch eternabond tape and call it a wrap.
Also It rained pretty hard the night after my install so fingers crossed that I didnít get any water penetration.
Thanks for all your help
Bob
seal
