Old 02-07-2021, 10:42 AM   #1
Help! I can't get anything to stick to foam ceiling to repair it!
Oh my. I tried to DIY my camper repair. Bathroom sunlight cracked, leaked water, damaged inside ceiling. I was successful with youtube and the exterior roof. I put in a new dome and sealed it! Hooray.
Then I got to the inside. I naively thought I should cut out the bad plastic ceiling and soggy wet thin wood. Now the thick foam is all that is exposed in the area right above the shower. Nothing will stick to it. I tried liquid nails to stick up some ceiling vinyl tiles. They fell down. (It was summer when I tried so was it just too hot?). I tried screws...obviously screws failed that doesn't hold into foam.
What can I put up there that will stick? I don't particularly care if the inside dome goes back up, but it would be nice. I'm just trying to get it ready to sell because we haven't used in YEARS since my boys started travel baseball. The rest of the camper is perfect.
Rockwood Roo Hybrid.
Thank you!!
shellandtheboys is offline   Reply With Quote
Old 02-07-2021, 11:31 AM   #2
have you tried 3M super 90 spray adhesive? Spray foam on ceiling ,let sit as in directions on can . Spray tile , let set . / dry . line up perfect. may want to sharpie in a grid ,or squares .Once placed you cant move the tile. They nake 3 M 110 also . This is a automotive product. Dont buy Elmers brand , not good quality for heavy duty use. OBTAIN a piece of foam ,a tile and try it on a table FIRST.
Thomas ho is offline   Reply With Quote
Old 03-28-2021, 10:03 AM   #3
THanks! I'm going to try this today!
repair
