Old 08-31-2020, 11:42 AM   #1
Help With Exterior Maintenance
Hello I have a 2017 Forest River Cherokee wolf pup 16fq. The vinyl cover located in the corner channels at the front of the trailer is damaged and cracking. What is the proper term for this stuff and can you please tell me where I might online order some replacement? Is the process more involved than just removing the old stuff and sliding the new stuff directly into the channel?
Thank you,
Ken
KenS999 is offline   Reply With Quote
Old 08-31-2020, 12:12 PM   #2
Any RV dealer on even on-line, you'll be able to find Rolls of Vinyl Covering for that channel. There are 2 different widths if I recall and you'll need to know which one.
TheWolfPaq82 is offline   Reply With Quote
Old 08-31-2020, 12:14 PM   #3
Thank you. It looks like one inch and black in color if anybody can confirm that.
Thanks, Ken
Old 08-31-2020, 01:39 PM   #4
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 08-31-2020, 01:42 PM   #5
Thank you. Was looking at some online right now.
Old 09-01-2020, 02:03 PM   #6
Amazon and eBay
Thank you,
Ken
It's available on Amazon and eBay. More color choices on eBay, I think.
Putting it in the channel is very straightforward. Terminating it at the ends may not be.
When you put it in the channel, be careful not to stretch it. In fact, compress it lengthwise and stuff it in. Why? Because it shrinks a little and you will have gaps at the ends if you are not careful.
On a vertical run like yours, you don't care if the bottom end is open--water runs downhill. Sometimes the top end is stuffed under the metal retaining track and everything is covered with a mess of caulk. If this is the case, it will be difficult to replace it exactly as it was done at the factory. Let us know what you find.
Larry
Larry-NC is offline   Reply With Quote
Old 09-01-2020, 02:07 PM   #7
Hello, I ordered some online and will be tackling it in 2 weeks. Thanks, Ken.
exterior, maintenance
