Old 12-06-2017, 07:52 PM   #1
Who Dares, Wins
doc73's Avatar
How do you lube your seals with slide toppers?
As the title suggests... Did some slide seal lube the other day before the trailer was put away for the season and figured there had to be better ways to lube the seal across the top of the slide under slide toppers. I used a telescoping car wash brush with a sponge duck tapes to a tire brush... It worked but someone must have a better way?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-07-2017, 02:29 PM   #2
jeff64's Avatar
6' aluminum pole with shaped plastic insert, also have a 6' extension. Plastic shaped insert wrapped with 6 x 9 gauze pad tie wrapped on.. saturate it with 303 and drag across the outside and then slip underneath seal and do it again. Work it from both ends of the slide if need be
ID:	157784   Click image for larger version
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
jeff64 is online now   Reply With Quote
Old 12-07-2017, 02:36 PM   #3
I pull my slide in about 6" and stop.
Then I go INSIDE and use a step stool to access above the slide.
Using a microfiber cloth with 303 Protectant, I can slip my fingers and the cloth between the slide out roof and the seal and wipe/treat the entire seal in about 1 minute.
Done! No poles, no duct tape, no fuss, no muss.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 12-07-2017, 02:44 PM   #4
jeff64's Avatar
There ya go Doc, one of those methods should giter done!
14K Equalizer
Old 12-07-2017, 05:58 PM   #5
Who Dares, Wins
doc73's Avatar
WHat is that insert? Or is it home brew?
You know that NEVER dawned on me to try... I will give that a whirl!
2015 ChevyHD D-Max
Old 12-08-2017, 03:54 PM   #6
I use Silicone spray for my lube. Able to crawl under my slide topper about 1/2 of my body, then I run into the skylight.
Portagie1968 is offline   Reply With Quote
Old 12-08-2017, 04:23 PM   #7
Which 303 Protectant do you use?
McCormickJim is offline   Reply With Quote
Old 12-08-2017, 07:21 PM   #8
Never did mine...waste of time and money in my opinion !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 12-08-2017, 07:57 PM   #9
2007 WildCat 32QBBS
18CrewDually's Avatar
I use the spray can that shoots a stream of foam. I can hit the seal from either side. I'm usually not that concerned with the top one anyways since it's protected from sun and rain. The side seals I usually hit twice a year.
18CrewDually is offline   Reply With Quote
Old 12-08-2017, 10:42 PM   #10
Novice Travel Trailer Guy
benchmarks's Avatar
Agreed
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 12-09-2017, 12:27 AM   #11
Canadian Member
I use this.
https://www.protectall.com/shop/slid...eal-treatment/
I spray it on a cloth and wipe as far in as I can reach from the sides. I may try some of the ideas posted here.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 12-09-2017, 09:36 AM   #12
Wolverine 1945's Avatar
An old sock taped onto a painters pole !!!
Wolverine 1945 is offline   Reply With Quote
seal, slide
