Old 04-11-2021, 08:50 PM   #1
Fluffywhitedogs's Avatar
How long to wait before putting eternabond over fresh dicor
I replaced my faulty Fantastic Fan with a new Maxxair. Installed it and sealed the edges and screw holes with dicor as per the instructions.
I previously had eternabond around it and I want to reapply it. How long should I wait?
(I did search through a lot of threads but didn’t see an answer!)
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 04-12-2021, 09:40 AM   #2
SeaDog's Avatar
this is a guess on my part I think I would wait at least 72 hours or longer before covering. Myself I would just leave the decor if it covered good. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-12-2021, 10:05 AM   #3
I def want to get eternabond on. It was on the old one and it looks awful now without it!
Thanks!
Carmen and the pack
Old 04-12-2021, 10:26 AM   #4
rsdata's Avatar
Thanks!
as long as the Dicor is semi-liquid and not yet hard to the touch I would leave the eternabond off... personally I would have put a piece of two-sided butyl tape under the fan edge, then applied the eternabond and skipped the dicor altogther...
2014 Shamrock 183
Old 04-12-2021, 10:42 AM   #5
Yea, I didn’t use my brain in that one. Lol the instructions said dicor and I blindly followed them 🤣[emoji22]
Carmen and the pack
Old 04-12-2021, 02:34 PM   #6
primo20's Avatar
Vote 2 for me too. I would have done eternabond first (probably only) then added dicor where needed. But I am certainly no expert.
primo20 is offline   Reply With Quote
Old 04-12-2021, 03:58 PM   #7
Witch Doctor's Avatar
When it’s dry to the touch, then put it over it.
Old 04-12-2021, 06:54 PM   #8
Putting Eterna bond over dicor
If the weather is between 50 and 70 Degrees Fahrenheit, the Dicor Self Leveling Lap Sealant takes 5 minutes to skin over and is waterproof after 4 hours. After 48 hours, the sealant is about 80% cured. It can take up to 30 days to cure to 100%. I would not lay tape over till the dicor is cured.
Justonemoe is offline   Reply With Quote
eternabond
