Old 04-29-2018, 06:25 PM   #1
larry2c's Avatar
Is this a normal way to seal a slider?
I haven't got a friend or neighbor close by with a slider that I could compare with so I figured I'd ask the FR forums brain trust. The roof seal of the slider appears to be sealed with duct tape (pretty strong looking duct tape). Is that normal? Should I put Eternabond on it instead (that might cause issues with the seal but I'm not sure)?
Here's a picture
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 04-29-2018, 06:29 PM   #2
Flybob's Avatar
Sure it is not Etrnabond like tape. That is what is on mine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-29-2018, 06:43 PM   #3
Censored Member
Eternabond comes in white, black, gray, and tan colors. Yes, what you are seeing is normal. Don't fix what ain't broken.
ManlyMan is offline   Reply With Quote
Old 04-29-2018, 06:59 PM   #4
larry2c's Avatar
I've not bought & used Eternabond but I've seen it on my roof around the vents, etc and it looks a lot thicker than this stuff. I took another picture from the front side of the slider and you can see a "pucker" that shows how thin it is - like duct tape. I wasn't aware that Eternabond came in colors other than the white/cream colored stuff I've seen on the roof so maybe this is it but it sure looks more like some kind of tape...
'11 F150 5.0
Old 04-29-2018, 10:21 PM   #5
Just as confused as you
Scrapper's Avatar
You can get Eternabond in different thickness. Look on their website. https://www.eternabond.com/
Richard & Jill
Old 04-30-2018, 07:10 PM   #6
Send a message via MSN to Tiggerdad
That's not duct tape. Either Eternabond or one of several knockoffs. Have that on my camper and have had no issues. Keep an eye on it and make sure there are no cuts or ripples that would allow water to get under it. It does look like a screw head is trying to pop through. I would think about cutting a hole where it is, tighten it and put a dab of Dicor on it.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-30-2018, 07:38 PM   #7
larry2c's Avatar
yeah, I was worried about that and the pucker spot.
Do they make smaller tubes of Dicor? I seem to only need small amounts and then it dries up before I get to use the rest of the tube...
'11 F150 5.0
seal, slide
